Can a PDR be installed
Old May 13, 2017 | 12:35 AM
mxkx250's Avatar
mxkx250
2nd Gear
Default Can a PDR be installed
I found a C7 ZO6 for a good price locally and it has the options I want except for PDR. Can it be installed?
Popular Reply
May 29, 2017, 02:28 PM
Jetblackc6's Avatar
Jetblackc6
pdr can be added.. I installed pdr into my 16 z06 buying all parts needed used and about 2 hrs of wiring. im also working on a write up with pics of it installed and should have it done in a week or so
Old May 13, 2017 | 12:46 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
No, not the factory one. There are some really good aftermarket alternatives that have superior picture quality and give you a lot of the same telemetry the factory system does. If you found a car you like, I wouldn't let the lack of a pdr be the deciding factor. At least, imo.
Old May 13, 2017 | 10:53 AM
mxkx250's Avatar
mxkx250
2nd Gear
Thank you for your answer. I am a Camaro "collector" and am trying to decide if I should sell and go to the ZO6. I really like the PDR and unless I wait for an 18 and lose all the discounts, I would have to settle for one without.
Old May 13, 2017 | 11:53 AM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
There are always discounts of course, but they change all the time :-)
Old May 14, 2017 | 07:43 PM
intake68's Avatar
intake68
Old May 14, 2017 | 08:27 PM
mountainears
Factory PDR is in the rear view mirror. You would need to replace the rear view mirror with some aftermarket one that was integrated into a new true view mirror if you wanted it in the factory location. Not going to find something that goes into the factory mirror.
Old May 14, 2017 | 09:28 PM
intake68's Avatar
intake68
What is the lense located in the pic? I thought that was the pdr camera???
Old May 14, 2017 | 09:41 PM
mountainears
Correct. Circled. My mistake, not in the actual mirror but integrated into the trim. Finding one to fit in that location would be challenging. You might be able to source the actual camera and integrate it into some other dash cam that supports an external camera feed, not sure if that exists though.
Old May 15, 2017 | 12:02 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Just thinking out loud here.
You'd need to pull the cover and figure out how much space is there then mount a camera if you can fit one. You can get a 12v to 5v mirror tap to power it off the mirror. The problem then is the memory card. You'd have to pull that cover to get at it, unless you gave it access for a cable to hook up to your laptop or just pull the camera through. That might work, lol. You'd probably still need to interface with the actual camera to transfer video if you fed a cable to it. That covers a bitch to remove too. I'd pass, just mount one to the mirror and power it there. Blackvue makes systems with both front and rear cameras, they're supposed to be pretty good.
Old May 29, 2017 | 02:28 PM
Jetblackc6's Avatar
Jetblackc6
Old May 29, 2017 | 10:17 PM
one eyed willy's Avatar
one eyed willy
Looking forward to that write up!
Old May 30, 2017 | 08:59 PM
60grit's Avatar
60grit
Wow, just what I'm and probably many others are looking for!
Thanks for your efforts.
Old May 31, 2017 | 10:14 AM
Drew27's Avatar
Drew27
What was the ballpark cost to do this?
Old May 31, 2017 | 11:28 AM
bradgto's Avatar
bradgto
in for the write up!!!
Old May 31, 2017 | 11:48 AM
Magister Ludi's Avatar
Magister Ludi
Me too.
Old May 31, 2017 | 03:21 PM
teddyca's Avatar
teddyca
You had me at hello lol
Old Jun 4, 2017 | 09:07 PM
dpirre's Avatar
dpirre
2nd Gear
Default Interested in PDR installation
Very interested in the install. Thanks. don@coatofchrome.com
To Can a PDR be installed
Old Jun 4, 2017 | 11:45 PM
village idiot's Avatar
village idiot
subscribing for info on adding it.
Old Jul 23, 2017 | 01:04 AM
Drew27's Avatar
Drew27
This guy forgot?
Old Jul 23, 2017 | 11:54 AM
davepl's Avatar
davepl
Why would someone claim this and then bail? So weird...
