Heads porting
Old Aug 3, 2017 | 08:42 PM
black_c7's Avatar
black_c7
Default Heads porting
I have a set of lt4 heads that im looking to do some porting on, who ported your heads ? what the flow after porting?
Old Aug 3, 2017 | 09:19 PM
MitchAlsup's Avatar
MitchAlsup
Did you look here?
https://www.corvetteforum.com/forums...r-pricing.html
Old Aug 3, 2017 | 09:21 PM
black_c7's Avatar
black_c7
Originally Posted by MitchAlsup
Already checked that but that isn't the flow that im looking for, i need some info for the flow and they don't have it
Old Aug 3, 2017 | 09:46 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I had TSP port mine. I'd have to look up the flow rates but they were exceptional.
Old Aug 3, 2017 | 09:49 PM
black_c7's Avatar
black_c7
That what im thinking to do, tsp has good flow numbers and good pricing also, but more air flow is better always
Old Aug 3, 2017 | 11:56 PM
FlatPlaneCrankDreams's Avatar
Katech $499
Old Aug 4, 2017 | 12:08 AM
black_c7's Avatar
black_c7
Originally Posted by mesparza
Katech $499
Its not about the price, i want something with info and some valve job, katech is flowing good air with out the valve job, but since im going to port then i want the best flow out of them
Old Aug 4, 2017 | 01:49 PM
Cordes Performance Racing's Avatar
Supporting Vendor
we use LME for our LT1/4 heads.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old Aug 4, 2017 | 04:05 PM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
We played with different valve jobs and were not able to get any more out of them.
__________________
Contact:
(e) zach@katechengines.com
Old Aug 4, 2017 | 04:12 PM
black_c7's Avatar
black_c7
Can you post the flow on lower lift rate? Because my cam will not be at .700 anywhere, i need some info
Old Aug 4, 2017 | 06:50 PM
black_c7's Avatar
black_c7
Is it worth the money compared to tsp? Is there going to be a big difference between them?
Old Aug 4, 2017 | 08:05 PM
Supporting Vendor
never used tsp for lt porting.
Old Aug 4, 2017 | 08:06 PM
black_c7's Avatar
black_c7
What about the flow rates ! Does it mean they are better when they flow more!
Old Aug 4, 2017 | 08:21 PM
Supporting Vendor
flow doesn't always matter, velocity is extremely important.
Old Aug 4, 2017 | 08:30 PM
black_c7's Avatar
black_c7
So make sure the runners are polished ? I think that will help with some velocity
Old Aug 4, 2017 | 08:34 PM
Supporting Vendor
no, it's not like that.
Old Aug 6, 2017 | 11:47 AM
cv67's Avatar
cv67
St. Jude Donor '05
flow isnt everything and polishing does zip,
your in northridge? Try WCCH they are closeby, Mamos not far either
Dont get too hung up on flowsheets and dyno numbers; those heads are decent out of the box so its going to take someone who really knows what they are doing to do them right.
To Heads porting
Old Aug 6, 2017 | 12:35 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
If you're referring to the stock heads, no, they are actuslly not that good. LS3 heads flowed better..
Old Aug 8, 2017 | 09:50 PM
black_c7's Avatar
black_c7
Already called wcch, they don't do them yet, idk if mamo does them will give them a call, so if not the paper and flow numbers are the things that i need to consider what should I consider?
Old Aug 8, 2017 | 09:51 PM
black_c7's Avatar
black_c7
Fyrearnt do you like your tsp porting?
