Misfiring - looking for help
Old Aug 10, 2017 | 01:20 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Originally Posted by stab1991
If you had that much oil everywhere, I'm sure it's in the intercooler too.
Not good news. Mine did that right after a blower install. Kept oiling very bad. Took it to my local tuner. The tune was too hot and was backed off but the damage was done apparently because it never completely stopped
oiling. I took a loss and sold it.
Old Aug 10, 2017 | 01:22 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Originally Posted by C7 Demon
Newest update.
found a temp gun, so I started the car. After a minute I checked every exhaust bank/runner right out of the cylinder. All of them were reading about 240, except one was 100 degrees less.
I'm not sure the cylinder order, I think that's #6 (the third one forward from the driver seat)
The cold one is your issue. The cold pipe tells you it is not firing like the rest.
Old Aug 10, 2017 | 01:26 PM
C7 Demon's Avatar
C7 Demon
What damage came of that?
Old Aug 10, 2017 | 01:29 PM
C7 Demon's Avatar
C7 Demon
Fully agree.
I checked all electrical possibilities. Swapped plugs, that didn't help. Then swapped wires, that didn't help. Then swapped coil packs, that didn't help.
I'm pulling the valve cover tonight and looking inside
Wish me luck
Old Aug 10, 2017 | 01:30 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Fully agree.
Wish me luck
Take pictures!
Old Aug 10, 2017 | 01:32 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Stand in front of the car. Look at the engine.
2,4,6,8 are on the left with 2 being the front
1,3,5,7 are on the right (driver's side) 1 being the front
Elmer
Old Aug 10, 2017 | 01:36 PM
C7 Demon's Avatar
C7 Demon
Elmer
#3 it would be then
Old Aug 10, 2017 | 04:14 PM
1LEThumper's Avatar
1LEThumper
Have you checked the injectors? Could be a clogged injector too
Old Aug 10, 2017 | 04:53 PM
C7 Demon's Avatar
C7 Demon
I have not. Do you think that could happen with only 11,000 miles and coincidentally the same time I do my first major burnout?
But it definitely is on my list if I find nothing wrong when I pull the cover
Old Aug 10, 2017 | 05:45 PM
robert miller's Avatar
robert miller
I really dont see it being the inj's with the pressure & this low miles. Man if so you had to get some really bad r dirt in the gas plus it would have to gotten thur the filter are it is so bad that it is blocking the line on the tank side of the filter. I really don't see this.
Old Aug 10, 2017 | 10:44 PM
C7 Demon's Avatar
C7 Demon
So... The valve springs look perfectly fine
I then did a compression test.
Cylinder #1 180
Cylinder #3 (the cold one) ZERO
that's not good
I think I need to pull the head completely now and see what damage is done down below 👿
Old Aug 10, 2017 | 10:46 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Cylinder #1 180
that's not good
I think I need to pull the head completely now and see what damage is done down below ��
Ohhh no's!!!! Mayhaps you blew the piston skirt and bottom ring land. ��
Old Aug 10, 2017 | 11:03 PM
  #33
robert miller
Default ttt
^^^ what he said man hate it for you if so I would for sure put in a good set of pistons & rings. Put her back together call it a day if I didn't want a cam in her also...
Old Aug 11, 2017 | 12:01 AM
  #34
C7 Demon's Avatar
C7 Demon
If it is the piston ring, and hopefully no cylinder wall damage, then it's time to upgrade. Go big or go home
