Front warning system
Old Dec 24, 2017 | 12:29 PM
Fuzzybatman's Avatar
Fuzzybatman
Cruising
Default Front warning system
can the front warning system be installed on a 2014
thanks
Old Dec 24, 2017 | 01:00 PM
bsedwebt's Avatar
bsedwebt
Try "Curb Alert" it works AWESOME - $150 and about 1/2hr to install - not factory but I love mine - no camera needed and no interface problems, no cutting, no drilling, etc... plug and play.
Old Dec 24, 2017 | 01:04 PM
Fuzzybatman
Cruising
I have that and mounted under vehicle maybe wrong place
where is yours?
Old Dec 24, 2017 | 02:06 PM
bsedwebt's Avatar
bsedwebt
Upper part of grill next to license plate (wide area) used the shorter/narrower mount provided - I did not want to lose ground clearance - it is at a sharper angle downward which really works great
Old Dec 24, 2017 | 02:21 PM
Flame Red's Avatar
Flame Red
Although many here are happy with the curb alert, many of us had one installed and found it suboptimal. If you come in at any angle, it will not alert you and then crunch! It also can be difficult to get to work with a spoiler or can get hit by high flying debris. So many of us have ripped them out and have gone with a camera. I did after my Curb Alert died.
There are many threads here on how to add a camera on the front of a '14 and '15. Many different ways to do it. I went with the http://indiwork.co.kr/. They are now plug and play. They are also sold in the US now. There are other vendors and other techniques.
Old Dec 25, 2017 | 12:46 PM
Fuzzybatman
Cruising
thank you
Old Dec 25, 2017 | 12:59 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I went with NavTool and the camera. Video comes up on the NAV screen when you "demand" it or when you shift from reverse to Drive.
https://www.corvetteforum.com/forums...tallation.html
Elmer
Old Dec 25, 2017 | 01:37 PM
Fuzzybatman
Cruising
Elmer
do you have a complete list of parts needed for install and approximate cost
Old Dec 25, 2017 | 02:12 PM
eboggs_jkvl
Moderator emeritus
I'm pretty sure the parts and prices are in that thread somewhere!
Old Dec 25, 2017 | 02:16 PM
eboggs_jkvl
Moderator emeritus
The HDMI cable I used was this: Amazon.com: AmazonBasics High-Speed HDMI Cable - 6.5 Feet (2 Meters) Supports Ethernet, 3D, 4K and Audio Return: Electronics Amazon.com: AmazonBasics High-Speed HDMI Cable - 6.5 Feet (2 Meters) Supports Ethernet, 3D, 4K and Audio Return: Electronics
The HDMI adapter to the iPhone I used was this: Amazon.com: Lightning Digital AV Adapter for iPhone 5, 5C, 5S, 6, 6 Plus / iPad Retina Display, mini, mini 2, mini 3, Air, Air 2 / iPod touch 5th Generation, 6th Generation: Electronics Amazon.com: Lightning Digital AV Adapter for iPhone 5, 5C, 5S, 6, 6 Plus / iPad Retina Display, mini, mini 2, mini 3, Air, Air 2 / iPod touch 5th Generation, 6th Generation: Electronics
Links in the thread
Camera was $20
navtool.com $300 (just looked).
Elmer
Old Dec 25, 2017 | 07:02 PM
Fuzzybatman
Cruising
Thank you
Old Dec 26, 2017 | 11:34 AM
davepl's Avatar
davepl
FWIW I put my curb alert UNDER the car. Basically just in front of that little air dam that's not supposed to be on dry-sump cars, if you know what I'm referring to.
I find that works pretty reliably, but it isn't perfect. Still, I haven't rammed my splitter yet and it's been a couple of years and 5000+ city miles and parking.
Old Dec 31, 2017 | 02:05 PM
Bill Dearborn's Avatar
Bill Dearborn
So which camera did you use? The installation manual leaves a little to be desired from a clarity standpoint. Does using this module screw up use of the PDR? It looks like the Nav options are only available in Korea but it isn't clear whether the stock Nav will operate if this module is installed. I rarely use Nav functions so don't need to add more Nav capability. Same goes for Smart Phone mirroring, I don't play with mine while driving so I don't need to mirror it.
All I want to do is add the front mirror to help save a $2000 front splitter from damage.
Bill
To Front warning system
