Spark plugs...
Old Feb 16, 2018 | 12:47 PM
Ghostnotes's Avatar
Ghostnotes
Spark plugs.....what are you using or suggest?
Or how about the gap??
Old Feb 16, 2018 | 06:28 PM
raylo's Avatar
raylo
I think I have about 90,000 miles left on my OEMs! ;-)
Old Feb 16, 2018 | 10:01 PM
Ghostnotes's Avatar
Ghostnotes
I left mine in when i sent them out for headwork.
Plus my heat range/gap has probably changed.
Old Feb 17, 2018 | 01:42 PM
Bill Dearborn's Avatar
Bill Dearborn
Stock work fine and they are good for 100K miles. No real need to change them. Little to no advantage to switching plugs unless you have modded the engine and changed the heat range required to work properly in the engine.
Bill
Old Feb 17, 2018 | 01:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
Leave them be no need to touch them. Ive lost power trying to change heat ranges, gaps etc
Old Feb 18, 2018 | 09:03 AM
mcoomer's Avatar
mcoomer
Bill
Given his comments, I believe he's correct to ask the question. At the very least the gap should be checked to confirm it wasn't disturbed. Can't answer your question about heat range without knowing what work was done. I'd ask the shop that did the work as a starter.
Old Feb 18, 2018 | 10:47 AM
Ghostnotes's Avatar
Ghostnotes
I did all the spec/design and assembly.....execpt for the machine work of course.
Usually i would go a range up since im up on compression, radical cam and headwork. But being unfamiliar with the LT/Direct injection, i figured I'd ask here.
I'm starting with ACDelco irridium.
Old Feb 23, 2018 | 04:34 PM
Eric_Hirschberg's Avatar
Eric_Hirschberg
3rd Gear
Has anyone tried E3 spark plugs and what are your thoughts on those versus the OE plugs?
Old Feb 24, 2018 | 11:32 AM
cv67's Avatar
cv67
St. Jude Donor '05
You will not gain anything period. These cars are 'smart" gm did their homework. Save your money....
Same goes with plug wires, when someone shows me a plug wire swap with a real 40hp gain Ill sign my car over to them.
To Spark plugs...
