Oil temp. sensor
Old Feb 19, 2018 | 01:26 PM
Bad Jake28's Avatar
Bad Jake28
Default Oil temp. sensor
Simple question. Where is it located on a C7 wet sump car?
Old Feb 20, 2018 | 01:04 PM
Bad Jake28's Avatar
Bad Jake28
Doesn't anyone know?
Old Feb 20, 2018 | 04:21 PM
ersatz928's Avatar
ersatz928
Unfortunately the GM Factory Service Manual (at least the 2014 version on AllDataDIY.com) seems to neglect including any information on the Oil Temp Sensor for wet-sump engines. I suspect it is co-located with the Oil Level Sensor, which is mounted in the oil pan, and the wires exit the side wall of the oil pan, on the passenger side.
The Dry Sump engine has the oil temp sensor screwed into the side of the oil tank, behind the passenger side fender.
Old Feb 23, 2018 | 10:09 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Our 2009 wet sump C6 with no oil cooler would show oil temp of 215-230 cruising the interstate at 70 mph.
Our 2017 with dry sump and oil cooler shows oil at 180-210 under the same conditions.
It would be interesting to know how much of the drop comes from the cooler, and how much comes from the different location of the oil temp sensor.
Old Feb 24, 2018 | 09:25 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
that picture looks familiar lol
I checked the 2014 helms manual and confirmed the dry sump sensor location and as you mentioned, they neglect to mention where the sensor is on the wet sump motor..
Ant
Old Feb 24, 2018 | 11:10 AM
Bad Jake28's Avatar
Bad Jake28
Ant
I have a similar photo to share. The sensor worked fine when the engine was reinstalled. But has since stopped working. I've reached the conclusion that it must be integrated into the oil level sensor. Although my trusty GM parts guy wants to sell me a sensor that looks exactly like the coolant temp sensor. And this is per my vin.
Old Feb 24, 2018 | 12:29 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Well, heres the thing. If you assume he is correct that it is the oil level sensor, do you know what is involved in replacing it? You have to pull the oil pan. Which means a metric crap ton of work lol
Old Feb 24, 2018 | 01:17 PM
Bad Jake28's Avatar
Bad Jake28
Ant
yeah not really wanting to go down that road again. I just added an external oil cooler/thermostat from improved racing. It has a port for a temp sensor. So i may just add a secondary gauge from that.
Old Feb 24, 2018 | 01:24 PM
BERETTA's Avatar
BERETTA
According to my AllDataPro the oil level and the oil temperature sensor are built into the same sensor.
Old Feb 27, 2018 | 06:41 AM
X25's Avatar
X25
Sr.Random input generator
On gen5 Camaros, there's an oil sensor, but it's not accurate unless oil is dangerously hot, and it also does double duty as oil level warning sensor. The oil temp displayed is calculated by ECU, using coolant temp, as well as average recent RPM, engine load, etc. It was a total shock to be when I found out, and I only started investigating when I installed a $1000 giant oil cooler, that had zero effect on oil temps displayed at the track. When the discussion continued, someone mentioned GM only installs accurate oil temp sensors on dry sump models.
This was with the LS3 engines, but it makes you wonder.
Old Mar 1, 2018 | 11:45 AM
ImprovedRacing's Avatar
ImprovedRacing
Supporting Vendor
I believe the wet sump oil temp sensor is integrated with the oil level sensor in the pan, and the dry sump oil temp sensor is in the bottom of the dry sump tank.
Old Mar 2, 2018 | 01:25 PM
Bad Jake28's Avatar
Bad Jake28
Thanks for the feedback everyone. I'm glad improved racing commented here. There oil cooler thermostat is a great product. I also used there raceflux product to wrap the An lines leading to and from the cooler. Very clean setup. Just wish i could see the drop in oil temp.
To Oil temp. sensor
