Need to fix body roll
Old May 2, 2018 | 01:45 AM
Bill Dearborn's Avatar
Bill Dearborn
You might need to raise the rear of the car to prevent that roll over damage. With those tires you are almost an inch lower in the rear than the stock car is. 26.5 stock diameter rear tire Vs 24.8 with your spec tire. Also with the 285 in the front Vs the stock 245 you are changing the balance of the car considerably. As you suspect you should probably increase the diameter of your front sway bar which will help reduce body roll and induce some understeer in the front to compensate for the larger tire width. Maybe look at the GM C7 T1 suspension kit. You get stiffer sways, new non adjustable shocks and new control arms that probably have stiffer rubber bushings so you have less deflection.
Bill
Old May 2, 2018 | 11:23 PM
joshuagtp56's Avatar
joshuagtp56
Cruising
Originally Posted by X25
I had those wheels before. They're 14mm more inside than my 18x10.5 ET51 forged wheels, and that makes a huge difference. Combined with significant lack of sway bar support and increased lean, they must have caused this damage.
FYI, I was able to use those wheels with no damage using 750#/700# coilovers and aftermarket sway bars. Here's the video of my best lap with these wheels and 305/660/18F, 315/680/18R Pirelli DH scrubs:
https://youtu.be/tjSg7PRvaHw
I don't see anything against using stiffer sway bars and single adjustable coilovers in the rules.
i do agree after market way bars are in my future. i wish i could find the rates of the afe sway bars. i talked to lg Motorsports and there input is to run less camber -2 front and -1.5 rear with there sway bars. right now i have -3 front and -2 rear. . i just wish there swaybars had more adjustment. i want to keep the mag ride at this point.
Old May 2, 2018 | 11:28 PM
joshuagtp56
Cruising
Bill
i thought about switching the rear over to a 19in. rear and 18in with 285. tire height world be 26.8 rear and 24.8 front. not sure at what point are cars computers start to dislike tire height differences.
i am looking into sway bars. my hope is to be able to find a front swaybar with the best rate to fix the balance issue with the stock rear one installed as well.
Old May 8, 2018 | 09:27 PM
4GS7's Avatar
4GS7
Did your splitter get caught on something?
What are your alignment specs?
Old Dec 18, 2018 | 03:02 PM
BrunoTheMellow's Avatar
BrunoTheMellow
Joshua did you ever end up making changes? I'm In the same boat trying to decide.
Old Dec 19, 2018 | 09:12 PM
JT Corvette's Avatar
JT Corvette
same here...though honestly im thinking most of the problem comes from removal of the rear sway followed by the tire height difference
