2019 Cold Startup Rough Idle/Shaking
Thanks for the input.
You would be amazed at the problems a loose plug wire can cause. I got a service rear axle and service stabilitrak message on the DIC that was cured by fixing the plug wire issue. At first seemed to me like an ingrown toenail causing a cardiac arrest, but in this world of interconnected systems and nannies, I guess....
I chased a random misfire for 6 months in my C6 , every once in a while I would feel a shake or a pull against the brakes . Ended up being a spark plug wire to close to the alternator that was inducing RF into the ECM , never set a code or CEL
Back to the OP's question. Depends on what you call rough , unlike the others my car cold starts and runs fine with no shaking ...
Dave
it is idling high to warm up the cats faster......
When operating in closed loop , which is everything except WOT , the o2 sensors work by varying the voltage signal that they send to the ECM which in turn riches or leans out the mixture
they have their own heating circuit and a reference temperature and voltage output that represents the proper air to fuel ratio
to cold and a higher voltage from the O2 sensor the ecm will lean out the mixture , to hot and a lower voltage signal, the ECM will richen the mixture .
This system leads to some over shoot both ways and you can see this in the short term fuel trims as they tend to bounce around
When the engine is cold it is set to run at a higher RPM and a slightly richer mixture for faster warmup of the cats because they need to be hot to work at optimum effeciancy . This is why you get that "raw" gas smell at startup as the cats are cold .....
the engine can run slightly rough during this period but it should not be real bad ..
Dave
Dave
As many people here on this forum know I don't make statements just to make statements , my posts are always backed up by data or my 40 years in the Automotive industry , and I am here to help people , which can be proven by the amount of THANKS that I have received by helping others
But since you just opened the door lets take a look at this article on how a O2 sensor really works since you obviously have no idea and made a snarky comment directly at me ..
yes An O2 sensor needs heat to generate the necessary signal but in no way does this heat come from " MORE FUEL " as you state and NO, I did not state what you stated just in different terms .....
http://www.autotap.com/techlibrary/u...en_sensors.asp
Dave
This element is what heats the O2 sensor up during the OPEN LOOP cold start and also during prolonged idle periods , not dumping more fuel
Dave
In the end, upon cold start up, the car DOES use more fuel until closed loop is achieved.
at first you said
You win ... I am done ... now time to get back to the OP's problems which was answered ....
Dave
