C7 unlocking problem
Old May 22, 2019 | 09:14 AM
rosecustom's Avatar
rosecustom
Default C7 unlocking problem
My 2015 has an unusual problem. If the car sits overnight it will not unlock itself as you approach the vehicle. The touchpad just doesn’t unlock. If I manually unlock it from the key fob it does unlock. Both key fobs react the same way. The odd thing is it will function properly the rest of the day. Next morning it’s back to the same ol problem
Old May 22, 2019 | 09:20 AM
Empire55's Avatar
Empire55
Mine did this exact thing as well. I changed the battery in my fob and it no longer does it. Doesn't really make sense why since the fob seems to work fine manually unlocking but it worked for me.
Old May 22, 2019 | 09:32 AM
rosecustom's Avatar
rosecustom
I figured that when both fobs did the same thing it must be a different problem. Hopefully it’ll be a cheap fix. Do the fobs require reprogramming?
Old May 22, 2019 | 09:39 AM
Empire55's Avatar
Empire55
Yeah with both doing that it might end up being something else, but worth a try for the 3-4 dollars the CR2032 battery's cost. No, my fob did not require reprogramming after swapping the battery.
Old May 22, 2019 | 09:44 AM
rosecustom's Avatar
rosecustom
Thanks. I’ll give it a try
Old May 22, 2019 | 10:27 AM
RonC7's Avatar
RonC7
The car battery could be going bad / weak if it is the original. This would explain why something doesn't work after the car sits overnight, but does work throughout the day.
Also - check voltage on the fob batteries. You can buy old stock and get bad ones. Fob batteries seem to last about 3 years once installed - does not matter if your primary fob or spare.
There is no programming in the fobs. The car is taught to recognize them. Changing the fob battery does not require any reprogramming.
Old May 22, 2019 | 10:49 AM
rosecustom's Avatar
rosecustom
Happened to have two new cr2032’s. Popped them them in and it looks like it did the trick. Thanks again
To C7 unlocking problem
