CCB conversion by Girodisk
So it's looking like I'll need to replace my front rotors on my GS ZO7, but it looks like with this conversion I can keep my calipers and itll be cheaper to convert them over rather than buying a pair of CCB rotors. $2500 for all 4.
Has anyone done a conversion? It's my daily driver so I dont need ceramics, this conversions seems to be a good deal.
Let me know if anyone has suggestions on it!
Thanks,
TK
Thanks,
TK
Few quick questions for you (and anyone else that has changed them out):
- How do you like them? How's the dust/noise?
- Was it pretty straight-forward on replacement? (Swapping the disks/pads, and that's it? No issues with the calipers, etc?)
- Are the options for pads limited? (From what it looked like to me, only a few pads worked with them..)
- Were you able to sell the old components? It would be great to be able to partially fund the change-over by selling the CCB components...
- Did you dodge the "my wife is gonna kill me" bullet?
All in all I will probably occasionally track the car, but more for fun and nothing super serious. The Z07 package is pearls to swine to me overall, but that's how it came and it was too good of a deal to pass up. All in all its my daily driver and just want to enjoy the car w/o worrying about spending a fortune for rotors/pads or dealing with screeching from the CCBs.
Thanks!
like any other iron rotors. 100% pad dependent
you have to tie back the brake wear sensors. Use zipties covered by aluminum heat tape if you're tracking. Otherwise electrical tape is fine.
no. The front pads are identical to the OEM iron rotor Z06 size. The rear pads are identical to the base model / z51 front size. So pads are widely available.
Only component to sell is CCB pads and rotors. If your rotors are shot. Well... But the pads go for about $500 used and in good condition.
If you can sell the rotors, in good condition, You'll make your money back.
Thanks!
I'm curious if dealerships will install these w/o issue or giving static about installing aftermarket.. while I probably COULD do it myself, I've not done a lot of brake stuff and being able to stop without failure is probably important.
Ken
