DIY alignment tools recommendation
I agree. Dialing in the right alignment using shims under the upper control arms is an iterative process that makes hub stands worth the investment. It would be cost prohibitive to pay for an alignment service to do it right.
Now a little personal experience on the upper control arm washers. On the C5's and C6's the upper shims (washers with a rubber center to hold them onto the bolts) are exactly the same as the ones on the C7. They are right at 0.1 inch thick. On a C5 or 6 they will add 0.3 deg of negative camber upon removal. On a C7 they are worth 0.4 deg.
My rig is a Z51 with 19/20 factory wheels and MPSS's for the track, and AS/3's for the street. The OM says to remove a max on one under each UCA support bolt, Z51, and none in the rear for GS and Z06. I asked a young engineer at a Museum HPDE why this is, and the answer is that under certain conditions of suspension unload the wheel can rub on the UCA. Also, when you got to aftermarket wheel diameters and offsets, the risk goes up for contact. I gave Eric a Point-by between T3-and T4 at ViR and chased him into the snake until his S/C plussed in. At 5A he was way up on the gator, and his RR wheel was off the ground maybe an inch. So, if his shock allowed full displacement of his suspension AND he had washers removed, he might have rubbed.
Now If you have the OEM rear toe links, it is possible to get the claimed track settings, of -2.0 camber and the specified caster on a Z51. Further, if you get close to these camber/caster settings, you will never get toe with the limit of the OEM link. Well, at least true for the 4 different C7 Z51's I have aligned. In fact, the best you can do leaving both washers in is -2.0 on the LR and -1.9 on the RR. Then you have to have the granatelli bars to be able to have camber and caster as independent settings AND get the needed toe setting. I trailer my car to the track, but as long as you can accept a 0 toe front and rear, you should be able to drive to the track with these settings.
People forget about tire inflation, The best guide whether you can drive in town with a given setting is what your corner wear looks like, what center wear looks like, and whether there is feathering on the corners (an early sign of too much toe either way). Slicks or close-to-slicks with big tread blocks will still scrub the corners if the toe is wrong, instead of feathering. So, if you are really scrubbing the corners on the track, then you probably need more camber, or change your driving style. If you are scrubbing the corners on the street, then you have either a toe setting problem, inflation problem, or poor driving habits. Often drivers that apex early will also scrub tire corners unnecessarily. This is because you need to add more steering and are probably at the fringe of understeer. So your car has had time to settle into a good body roll, and you now have to ask for more turning to get through the corner. With a lot of body roll, the limit of camber gain due to suspension compression is done, and the tire contact patch begins to diminish. Same deal on the street. Always think late apex at every intersection where you turn. You will eventually find yourself making very crisp and efficient turns, and will be in oncoming traffic for a shorter duration.
I have resigned myself to -2.0camber/0caster LR, -1.9camber/0caster RR, 0toe rear; -2.2 camber/-7caster, 0toe both fronts. This is without removing any washers. I was starting to get nervous about removing the UCA bolts so many times to add/subtract washers. The sight of little metal slivers on the bolts was the first sign that this is beginning to be a really bad idea. I'm not opposed to having to put a helicoil in every once in a while, but once you put one in and then screw that helicoil up, your options go way down. Besides the thought of buying and installing 16 is not particularly appealing.
This reply is NOT a testimonial for the Granni links. In fact they are hateful as all get out to use and make adjustments due to the fact that the jam nut on the outer link is in the barrel of the wheel and a bear to get tight with out gouging the wheel.
I hope we haven't strayed away from the OP's original question. I just want to help with some observations of aligning nuances and driving habits seen in others.
I replaced the dog bone bolts with studs so I could avoid the problem of wearing out the threads in the frame. Got studs from Summit and nuts from Grainger. That way I can go from a track alignment to a street alignment at the end of the track season and back the other way in the spring. With my car I add an equal number of spacers behind the dog bones front and rear to get camber change without affecting caster. Then adjust toe.
Here is the info on the studs and nuts:
C7 Upper Control Arm
Double Ended Stud for Dog Bone:
Short Side 15mm of thread, Blank Section 15 mm, Long Side 35 mm
Dorman 675-576 Double-Ended Stud
Harbor Freight shims:
PITTSBURGH® AUTOMOTIVE
Body Shim Assortment 144 Pc
Two 1/8, One 1/16, One 1/64 = 8.41 mm or about 3.272374 GM shims or about 1.3 degrees in camber.Lock Nuts
Grainger:
FABORY
M10-1.50 Nylon Insert Lock Nut, Zinc Yellow Finish, Class 10 Steel, Right Hand, D985, PK100
Item #26LJ98 MFR Model #M12450.100.0001
One thing that needs to be done to get to the rear dog bones in the rear wheel wells is to cut the wheel well liner so you can get a socket wrench on the bolt/nut. An Exacto Knife works quite well to cut the liner.
Bill
Herman
There are really only 2-3 practical reasons why the car at rest would not be at the intended ride height. One would be a high friction bind in one or more of the control arm bushings, a bind in the sway bar, and some residual restraint in the shocks. Since we're in the C7 section, and assuming we are not talking about coil-overs, then the #1 reason is there some retained force in the shocks. Usually if you disconnect a shock, it will become shorter as this residual is relaxed.
So the short answer is a small pull down on the cradle and a small push up will "settle" the car to a consistent ride height. Of course, this is one of the sources of error and repeatability we all face. This is assuming zero friction of the tire to the surface, so you are either on a greased griddle, turn plates or hub stands. What I find more important than jouncing the car, is to lower the car on the turn plates with the turnplate locking pins in place, then tap the back side of the turn plate until the locking pins can be easily pulled out. Then I know my tires are free to camber as they want and roll enough to allow adjustment. I've tried the stack of grocery bags, poly sheets, but turn plates will give me good repeatable outcomes, even when I forget to "settle" the car.
I guess everyone knows that the Corvette suspension is a "short arm/long arm double wishbone suspension" When camber is set at the static ride height, this is the minimum camber any tire will see, when the car is going straight with no steering input. Any loading or unloading will increase camber. The exception is the inside front wheel in a turn which goes positive camber upon turning. This can be seen in the measuring of front caster. There is a good animation on You tube about this suspension and worth watching.
K....6, your detailed reply with the specific washer thicknesses and their correlation to change in camber are very helpful. Thank you. You've inspired me along with the other posts to take a hard look at the special uca bolts and shim kit. That also means getting hub $tands. Last week, I took the car to the dealer to set up a track alignment. Yureka, I have a new amazingly planted car. Since the car was purchased, it never felt planted. I came from a '15 Z51, and the Z06 did not feel right from an alignment perspective. After the track alignment, WOW! The technician walked me through the specs and now the rear caster is +.9. The rear lca are marked with yellow paint indexed to the lower edge of the cradle.
I see a need to adjust the alignment back to street settings and the posts offered here are a tremendous help. Thanks again everyone for chiming in! First lapping experience in the Z06 at Pacific Raceways was phenomenal.
