DIY alignment tools recommendation
This equipment measures a tire's individual toe. From my initial session, I found the right front toe measured 37/64" out, and the left front toe 34/64" in. If my mental math is right, then the total toe is 3/64" out. The total toe is relatively close to track-alignment specs. However, I'm concerned about the difference with the individual tires. Is this current measurement worth adjusting? And, if so, is my adjusting front-toe process the best way to do it? ( After a 15 minute search, I could not locate instructions on how to adjust front toe for C7s.)
Adjusting front toe:
0. Level vehicle
1. Place low-friction plate underneath tire
2. Center steering wheel and secure
3. Loosen nut, yellow arrow
4. Adjust bolt, red arrow
5. Measure for desired change, tighten nut
6. Test drive to settle suspension
7. Measure again, repeat steps 1-7 as necessary.
dealer setting
Camber
wheel rear
wheel front
What are you using for step 2? There doesn't appear to be anything under the tires so they are free to slide.
Recheck the string setup if the strings are not perfectly parallel then any error will end up in the final settings of the car.
If the measurements you are getting are real (not caused by the two items above) then your math is right you will have a bit over 1/16 toe out per the OP's second post. However, since the two front wheels are connected together by the steering rack, such a difference should show up in the steering wheel not being perfectly centered. The string is almost a mm thick, you might need to think about the error that can be introduced by this.
One thing that will screw up your work is jam nut tightening. The yellow arrow points to it. When you think you are done and the settings are dialed in, tightening these nuts will add 1/32 toe out each side. So, to compensate, adjust to 1/32 toe in each side, tighten the jam nut, check again.
Installed the AMT bolts in the front and added HF shims to set up for street driving. From the AMT brochure, a 1/8" shim equals .6 degree. I added a total of 1/4" to see if that corresponded to the desired change in camber. On the passenger side, the reading changed from from -2.0 to -1.4 with two 1/8" shims. On the driver's side, 3/16" in HF shims changed the camber from -1.7 to -1.1. At least it went in the right direction. I'm ok with these readings for the street and measured the original washer thickness to set it back for the track.
My question is, with the asymmetrical shims added to the front, (left side versus right side) are these new toe readings expected?
On the side where 3/16" shims were added, the toe went from slightly positive to zero. On the 1/4" side, the toe changed significantly from 1/32" in to 5/16" in. (From my trial size of two, adding positive camber moves the toe measurement in.)The steering wheel is still aligned TDC. Thanks again for all the other posters referencing the AMT bolts and HF shims. Very helpful!
So maybe a rule of thumb will help. if you only change camber on one side, then toe adjustments should only be needed on THAT side. Maybe a tweak to center steering wheel on the other side. Extending this rule of thumb. more toe adjustment will be needed on the side with the most change in camber setting.
In the front total toe is what counts, along with centering the steering wheel. It is fine to measure it individually, but the sum is what counts. Really, if things are right and you have 1/16 total toe, then each side should contribute 1/32. obviously, if you shoot for 0 toe, then each side HAS to contribute 0 (this is a dumb observation, but I'm on my second glass of Crown-R)
When fine adjusting the steering wheel, If it is rotated slightly to the right, then to fix that, add one flat of toe increase on the right toe link and take out one flat on the left. this will turn both wheels to the right. Then to compensate, you then need to turn the wheel to the left to steer straight ahead. Drive it around the block. Usually, one or two times is all it takes to get the wheel back centered, and if you are careful how you measure one flat of rotation each side, there probably is no reason to go back and measure toe again. This is an estimation, but one flat is worth 1/64 of individual toe, plus or minus a bit of KY windage. After all the location of the toe rod sucks, and it is dark. When both hands have wrenches, the only other place for a light is in your teeth.
As soon as I left the driveway for a test drive, I felt the car has much less rolling resistance. Going from 5/16" to 1/32" toe in was noticeable or very wishful thinking. Thanks again for helping out big time.
Grease pencil from HF help me keep track of the turns.
After getting the initial read out from Tenhulzen, went with two tapes so I could work under car.
Once thing you can do is just measure total toe directly on the tire tread. The rain grooves in the sticky tires like MPSS are near perfect with very little runout variation. just pull a tape measure from left to right and measure the edge of the groove. You will be good to a bit less than 1/32 with a simple tool. just measure at the same height from he ground at the front of the FRONT tires and compare to the same measure at the back of the FRONT tires. That's what I do at the track if something gets loose. Take a bar of soap and scrub the crap out of the pavement with the bar to make a slick surface layer for the tire. Actually works and the mess goes away next rain. Motel soap is pretty good for this.
When following the directions in a previous post, I either have a straight steering wheel or desired toe settings. But not both.
What am I missing?
Are the lift treads level? That will throw everything off, as the car will be locked against the rear wheels to prevent rolling off. Your pic looks like it is sloped.
It looks like you are using a string setup. So a string setup provides a reference pair of lines that are parallel to the long axis centerline of the car. Since there is no mark (called a fudicial) on the car, the centerline is basically imaginary. So the strings are set up with respect to the hubs, and more importantly at the very center of the hubs, so that camber setting changes are not affected by the parallel string lines. The accuracy of your string setup will dictate the accuracy of your alignment. The lasers I use (and the high buck commercial rigs too) have a beam spread issue that requires a little Kentucky windage to reduce error. In the end a good string setup is as good as lasers, and for a number of reasons, you can produce a better alignment than many shops. The shops have to make money, you have to make it right.
So for argument sake, let's say your strings are perfectly setup, your tires are free to rotate easily, and your steering wheel is tied down and perfectly centered. THEN, setting toe is a matter of going to each tire and adjusting each with respect to the string to get the desired final toe.
To make your life easier, shoot for zero toe on each side. Unless you are the hottest shoe at the track, the OM-recommended -2.0 camber front and rear, and zero toe front and rear will give you a darn nice handling track day car.
Then, you can experiment with front and rear camber/toe settings on future track days to optimize alignment to suit your driving style. We aren't robots, so each of us run our cars a little differently. The pro racers are different. They can succeed with some really bad settings.
Finally, you have a Z06, I think. Be careful with the UCA shims, your tires may rub stuff. That's why the OM has restrictions on shim removal. If you run a track-day on a banked oval, you might run into rubbing. After market wheels with different offsets? mmmm
For the shim removal, there are two per AMT bolt, and removing one shim per bolt gets the camber back to track specs. Easy, glad I installed them.
Yes, the ramp is sloped. Will the slope make a difference in setting toe? I can get the ramp level if needed. Thanks again for the reply. I really appreciate the help!
For tying down the steering wheel, what I do is use the button on the side of the column to lower the wheel. Then I cross-tie the steering wheel to the seat frame. Once tied down, use the button to adjust the wheel up and really put a tightening on the cross ropes. when everything is tight look at the steering wheel, give it a few wiggles,and see if it returns to rest exactly centered. I don't tie down the steering wheel until I have the rear settings done, and NEVER tie it down unless the tires are on a slick surface or turntables. some sort of adjustment on the ropes is needed to make sure the tension on each is close to the same.
Regarding shims, be really careful adding a lot of shims. you could get rubbing of the tires on the car, or wheels on suspension parts in high suspension compression like ovals or big carousels
Get the car level!
Get the wheels to move freely--two plastic sheets cut by the technician at Lowe's. The pieces could be less rectangular, but it worked. A few squirts of 3 in 1 oil between the plastic pieces lowered the mu.
Secure the steering wheel-I am sure there are better approaches. One 40" and 24" bungees used. I am back on the road and headed to the track!
Get the car level!
Herman
