Rear clutch pump
Old Aug 20, 2019 | 09:43 AM
deens's Avatar
deens
4th Gear
Default Rear clutch pump
My service rear axle warning came on and they say its the rear clutch pump. anybody heard of this/
Old Aug 20, 2019 | 10:21 AM
Null Pointer's Avatar
Null Pointer
Exception ID 10T
If you have the electronic limited slip differential, then yes there is a separate reservoir for the eLSD clutch packs and there is a "rear differential clutch control module" pump/solenoid that needs to be cycled to bleed the system when you change the fluid. So they might not be blowing smoke up your butt to get some big service $$$. How did they determine it was the pump?
Old Aug 20, 2019 | 10:24 AM
deens's Avatar
deens
4th Gear
The service rear axle light came on the display. They have already replaced the transaxles when they were trying to solve the shuddering problem. They now have change the fluid with this new stuff that came out in Feb. Thank goodness this has all been under warranty.
Old Aug 20, 2019 | 10:37 AM
Null Pointer
Exception ID 10T
Sorry, not much more I can offer. Hopefully they checked the fluid level in the differential (not the eLSD clutch pack unit). The factory tends to underfill them. The "new stuff" you mention that came out in February is trans fluid, guessing you have an A8. Good luck and I hope they get it resolved for you. There are quite a few threads in the forum about the "Service Rear Axle" message. Use this command in Google search >>> site:www.corvetteforum.com "service rear axle" <<< Here are a few of the results.
Service Rear Axle message - CorvetteForum - Chevrolet Corvette ...
https://www.corvetteforum.com › ... › C7 Corvette › C7 Z06 Discussion
Jun 6, 2017 - C7 Z06 Discussion - Service Rear Axle message - I have just had error Service Rear Axle while on track and could not use PTM - car limped ...
"Service Rear Axle" - What should I expect? - CorvetteForum ...
https://www.corvetteforum.com › ... › C7 Corvette › C7 General Discussion
Apr 11, 2018 - I wonder if disconnecting the battery would reset the "service rear axle" message. Right now it comes on each time I start the car (before driving) ...
Service rear axle warning message - CorvetteForum - Chevrolet ...
Mar 15, 2018 - C7 Z06 Discussion - Service rear axle warning message - So, I started the car today and up popped an amber Service: Rear Axle, light.
Service Rear Axle warning came on. - CorvetteForum - Chevrolet ...
https://www.corvetteforum.com › ... › C7 Corvette › C7 Tech/Performance
Jan 19, 2016 - Got side ways so I got out of it right away (that boost ). My dash display warning came on for Service Rear Axle . I dismissed it the warning ...
To Rear clutch pump
