Auto dim mirror
Old Jan 19, 2020 | 12:33 PM
Corvette-Dan's Avatar
Corvette-Dan
Default Auto dim mirror
Can the auto dim rear view mirror be turned off? Where is the light sensor that activates it?
Old Jan 20, 2020 | 10:10 AM
ersatz928's Avatar
ersatz928
https://www.corvetteforum.com/forums...upgrade-3.html
In the above thread, see Post #38 and #40, to disables the autodimming.
Old Jan 20, 2020 | 10:24 AM
Corvette-Dan
Thank you. I can never seem to find exactly what I am looking for when I try to do a search? I do not know why. Do you still have that 1LT mirror?
Old Jan 20, 2020 | 11:01 AM
ersatz928's Avatar
ersatz928
I might...let me check.
Old Jan 20, 2020 | 11:03 AM
JMII's Avatar
JMII
Use google to search just this site using the following format:
”term site:www.corvetteforum.com”
remove the quotes and replace term with your search words.
I disconnected the wire harness behind the mirror, very easy to do as the plastic cover just snaps on & off. I did it mostly to get rid of the OnStar lights but it will kill the auto-dim as well. With tinted windows I don’t miss the feature unless some lifted truck is behind me.
Old Jan 20, 2020 | 04:51 PM
Corvette-Dan
Thank you
Old Jan 21, 2020 | 05:18 PM
ersatz928's Avatar
ersatz928
If you want to keep your Onstar, and you don't want to put the sticker on your mirror (to block the sensor), you can cut the wire to Pin #1, and add a small jumper wire at the connector, from Pin#1 to Pin #2...then the mirror will never autodim (it thinks the car is in reverse all the time).
Old Jan 28, 2020 | 09:17 PM
427C62013A's Avatar
427C62013A
So after looking at the wiring to the mirror I found that the original wiring diagram was not accurate. There is no reverse 12 Volt wire on the car side. There is no ignition wire on the mirror side. There must be a data bus transmission for operation. So I took a chance and put a switch on the 12Volt Battery red wire on mirror side of the plug. This does in fact remove power from all functions of the mirror, the Onstar lights, and the auto dimming circuits. Turning power back on restores everything to normal operation. I mounted the switch in the plastic cover.
Below is a corrected diagram.
Old Feb 1, 2020 | 05:52 AM
427C62013A's Avatar
427C62013A
Power Switch for rear view mirror.
Old Feb 6, 2020 | 03:43 PM
AKKutz's Avatar
AKKutz
I replaced mine with the 1lt pack manual mirror.
Old Feb 13, 2020 | 02:02 PM
DailyDrivenCorvettes's Avatar
At least once during every drive I find myself scaring myself into mistaking the blue Onstar light for a cop car behind me. I hate how bright those lights are.
Old Feb 14, 2020 | 07:39 AM
427C62013A's Avatar
427C62013A
You have several options to address those bright lights:
Black Electrical tape over lights.(Still maintains Auto Dim, Onstar still works just can't see the light.). Cheap.Easy.
A manual mirror from the 1LT. (Onstar Lights - Could be left unplugged.) Cost of mirror. $$
Disconnect the mirror.(lose Auto Dim and Onstar.) Free. Easy.
Install a switch.(Most difficult option involves soldering wires, but can restore full functionality in seconds with Onstar lights and Autodim.) Cost of switch. $
Old Feb 14, 2020 | 09:57 AM
AKKutz's Avatar
AKKutz
[QUOTE=427C62013A;1600959449]
A manual mirror from the 1LT. (No Onstar.) Cost of mirror. $$/QUOTE]
The 1lt manual mirror still has the lights.
Old Feb 14, 2020 | 10:50 AM
427C62013A's Avatar
427C62013A
Thx
Old Feb 14, 2020 | 01:12 PM
Elk's Avatar
Elk
I like LightDims to cover LEDs, etc.
Clicky Clicky
Old Feb 14, 2020 | 01:33 PM
JMII's Avatar
JMII
That was my choice those lights drove me nuts and I could careless about...
However I gotta say your switch install looks great.
Old May 27, 2020 | 11:00 PM
jkstew1's Avatar
jkstew1
Default Auto Dim Mirror Disconnect
I got the cover off behind the rear view mirror, but how the heck do the plugs disconnect? They don't want to come apart and I don't see any tabs to push.
To Auto dim mirror
