Tune required when installing longtube headers?
Old Feb 15, 2020 | 02:34 PM
Pjmc15Z51's Avatar
Pjmc15Z51
Default Tune required when installing longtube headers?
I put long tube headers and a catalytic X-Pipe on my otherwise stock LT1 engine. It’s popping and sputtering once the engine starts to warm up a little and is basically undriveable. I took it down to the dyno for a retune and he said that it’s an installation issue, the tune won’t be that far off. He said the car should be be drive able and not need retuning. Does an otherwise stock engine need to be retuned, and it’s not driveable if not? Or do I have an installation problem? Which would be with the O2 sensors.
Old Feb 15, 2020 | 03:19 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
First check that the O2s are not crossed
and
Then RUN like Hell
You need a Tune with LTH...
Regards
Chip
__________________
..................Click for
Old Feb 15, 2020 | 03:30 PM
-ZEEOHSIX-'s Avatar
-ZEEOHSIX-
Here's my take on it--any time you mess with the air/fuel ratio of the vehicle by changing parts that impact it, you should get a tune/retune. Sure, you could drive the vehicle with longtubes and no tune but, it doesn't mean that you should. To me, committing to putting longtube headers on a car is also committing to getting it tuned. There's an old adage that tends to be overlooked these days; just because you can, doesn't mean you should. Get the install issue squared away and then get it tuned.
Old Feb 15, 2020 | 05:41 PM
Dcasole's Avatar
Dcasole
You car will run without a tune , you will be leaving a lot of power on the table but .....
You will have a CEL for the rear O2 sensors but as said above the most common mistake the O2 sensors are plugged in wrong , the right is on the left and the left is on the right or …… you have a exhaust leak , retorque all the header to head bolts or … you somehow damaged the O2 sensor
Dave
Old Feb 15, 2020 | 07:18 PM
T/A KID's Avatar
T/A KID
Make sure plugs didn’t get a crack anywhere when doing headers.. seen this many times
Old Feb 16, 2020 | 10:56 PM
Avanti's Avatar
Avanti
A tune would be desirable, as noted, to maximize the results. However, something has been f**ked up during the installation process. Yes, it IS an installation problem. Others have suggested where to start your diagnostics. Btw, has it set any CELs (seems you would have noted them, if it had)? All the best.
Old Feb 17, 2020 | 01:46 AM
GeorgeR_Zed06's Avatar
GeorgeR_Zed06
I installed long tube headers with off road x pipe and a k&n cai on my 2014 Z51. It ran flawlessly and when I went in to get a tune, it only picked up 3 hp and 3 tq. Nothing major was changed. A tune is optional, but not required. As far as HUGE gains, not a chance, unless the dyno shop is fudging numbers for advertisement purposes (which is what I see a lot of on here).
Old Feb 17, 2020 | 07:06 AM
Dcasole's Avatar
Dcasole
if you only picked up +3 HP with a tune and a set of long tubes ..... you need to look for another tuner ......
Dave
Old Feb 17, 2020 | 07:51 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Dave
No question.
Old Feb 17, 2020 | 10:02 AM
Fore58's Avatar
Fore58
Need some base numbers if available.
Old Feb 17, 2020 | 10:08 AM
Pjmc15Z51's Avatar
Pjmc15Z51
Mine was 377 with a KnN, 407 with the tune. I’m hoping for 30 with LT headers, hi flow cats, and after market mufflers. Sound reasonable?
Old Feb 17, 2020 | 06:08 PM
GeorgeR_Zed06
Yes.
Mine stock it was at 403 rwhp.
I added long tubes and a k&n cai and went in for a tune. The A6 put down 444 rwhp.
Then, I got it tuned and it only picked up 3 hp and 3 tq for a total of 447 rwhp.
Old Feb 17, 2020 | 06:17 PM
GeorgeR_Zed06
Dave
No, let me clarify that, lol!
I added long tubes and a k&n cai and went in to put it on dyno before tuning. The A6 put down 444 rwhp.
Then, I got it tuned and it only picked up 3 hp and 3 tq for a total of 447 rwhp. Basically, a 44 HP increase over stock (not too shabby).
I drove my car around for quite a while with the mods prior to tuning, so the LTFT's probably tuned the car on its own, lol. Remember, we're talking LT1 here, not my C7 Z, that's a whole diff ballgame there
Old Feb 17, 2020 | 06:52 PM
Dcasole's Avatar
Dcasole
Lol .... and you have to also take into account different days , different temperatures, different DA and all the other variables. The only way to compare apples to apples would be to do a baseline then do the mods all on the same day and even then there will still be some variability
The real measurement is the 1/4 mile ....
Dave
Old Feb 18, 2020 | 12:33 AM
GeorgeR_Zed06
Dave
That's true. Unfortunately, I couldn't install everything in one day and then have it tuned. The time frame when I did everything, the DA was between 6300 and 7500 feet. Our DA is always horrible. I also agree with the 1/4 mile being the real measurement, that's why I pay little mind to dyno numbers. My 1/4 times and trap speeds are pretty comparable to other higher HP cars.
Old Feb 18, 2020 | 03:42 PM
Dawgbroke's Avatar
Dawgbroke
I understand that rwhp is the real test.
Just curious, but how does that translate to Crank HP?
Old Feb 18, 2020 | 06:15 PM
Pjmc15Z51's Avatar
Pjmc15Z51
Depends on your transmission if we’re talking a typical street machine. Drivetrain losses in an automatic are roughly 18%, 15% for a stick.
Old Feb 18, 2020 | 08:09 PM
Dcasole's Avatar
Dcasole
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^^^^^^^^^^ THIS ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^^
Dave
To Tune required when installing longtube headers?
