Rear diffuser from Corvette Mods - Template?
Old Dec 20, 2020 | 03:54 PM
Timscherer's Avatar
Timscherer
Default Rear diffuser from Corvette Mods - Template?
I recently purchased a set of rear diffusers for my c7 Corvette from CorvetteMods.com. I was not provided a template for drilling into the rear bumper, has anyone had this issue with CorvetteMods.com?
I have a method that I can use to transfer the holes from the diffusers to the bumper, however I would prefer to use a template - Any suggestions?
Thanks for your time and information.
Tim Scherer
Old Dec 20, 2020 | 06:10 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
Can't help you with a template.
But they are banned here for a reason - but at least you got a product shipped. Search and you'll see complaints.
Good luck!
Old Dec 20, 2020 | 07:07 PM
Timscherer's Avatar
Timscherer
Dtom, thanks for your reply. Didn't realize that CorvetteMods.com had a bad reputation. Everything that I have ordered from them was as expected. I will keep that in mind for future purchases.
Old Dec 21, 2020 | 08:35 AM
RugbyRef1's Avatar
RugbyRef1
@Timscherer ...I installed rear diffusers from ACS. I ended up removing the rear lower valence to do so. Although I had the template (tossed in the garbage), I was able to line up the fins perfectly with the valence on the workbench. The template helped...somewhat. I ended up discarding it and used a tape measure. The fins are aligned along the contour of the valence. Try carefully sliding one of the fins around on the valence and you'll see what I mean. Good luck!
Old Mar 22, 2021 | 01:49 AM
Genovo's Avatar
Genovo
Default No template here either - WTF?
I also bought the diffuser fins from Corvette Mods as I wanted painted ones in Shark Gray. I wrote them and they said sorry, no template provided. Interestingly, the fins they sell are made by EOS (extremeonlinestore.com) and if you look on their website, they provide a template with their fins. I don’t understand why Corvette Mods doesn’t get the template for the EOS fins they buy and resell when EOS provides it. They gave me a hard time about it and so I will never again do business with Corvette Mods.
I sent a request to EOS for the template but they never responded - so F them too.
What I am going to do? I got some strips of vinyl sign stock from a friend who owns a sign shop. The vinyl has a sticky side after the tape is pulled. I will set the vinyl strip Non-sticky side on the mounting side of the diffuser fin with some small pieces of light tack painters tape and pierce the vinyl strip where the 3 screw holes of the fin are. Then I will locate the mounting positions on the rear valance of the car with a tape measure to ensure even spacing of the 2 fins going onto each side. I will remove the tape on the back of the vinyl strip attached to the fin and place the fin at the proper location mark on the valance so it sticks when I remove the fin. Finally I will drill the 3 mounting holes through the now transferred vinyl strip. This is my work-around for getting the mounting holes positioned properly before attaching the fins. Hope this helps.
Old Mar 25, 2021 | 12:51 AM
Timscherer's Avatar
Timscherer
That is an excellent idea, thanks for sharing.
Old Apr 6, 2021 | 09:28 AM
brocco's Avatar
brocco
3 words CORVETTE MODS SUCKS
if you still need a template, send me a note
Old Dec 29, 2021 | 05:11 PM
neu318's Avatar
neu318
2nd Gear
Hi Brocco,
Long shot here but do you have the template available? Can you email it to me at jorged318@gmail.com? Thank you
Old Jan 1, 2022 | 09:53 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
It's probably an ACC piece. Contact them.
To Rear diffuser from Corvette Mods - Template?
