diff fluid
Old Feb 21, 2021 | 03:51 PM
vette10''s Avatar
vette10'
Default diff fluid
replaced rear diff fluid, everyone says it holds 3 gts and will start coming out once all 3 are in, i pumped in 3 quarts and never started coming back out, would you buy another qt and put in just little more until it comes out the fill, or is it sufficient with what i did. only 2 qts of old oil came out
Old Feb 21, 2021 | 07:17 PM
seniorstorekeeper's Avatar
seniorstorekeeper
I really don't know how much trouble it is to change or add the rear differential fluid to the car, I have not replaced mine yet but plan to before summer. If it is an easy process to add a little more fluid to it, I would probably pick up another quart and add some. I always liked to see a little fluid coming out before I replaced the plug. But if it is a pain or aggravating job to do, probably what you did will be sufficient. You know you drained two quarts and added three quarts so you have to be better off than you were. I would bet it is just barely below the filling hole.
Old Feb 21, 2021 | 07:18 PM
C7&7's Avatar
C7&7
I would fill it till its full or you can feel it with you pinky. It's probably very close right now.
Old Feb 21, 2021 | 07:46 PM
robert miller's Avatar
robert miller
Default ttt
I agree it takes just a little over that, I just started putting in one good pump on the 4th & it started coming out.. But I also use a small bottle of add to it also. Robert
Old Feb 21, 2021 | 08:41 PM
ronsc1985's Avatar
ronsc1985
Depending on how you have the car jacked up it may take/drain a bit more or a bit less then 3 qts. Either way it isn't a big deal. Just add it until some comes out the fill hole
Old Feb 21, 2021 | 08:44 PM
vette10''s Avatar
vette10'
not to hard to get to, as long as you have the little hand pump and tubing its pretty simple
Old Feb 22, 2021 | 09:35 AM
C7&7's Avatar
C7&7
That's a good point. If the car is jacked up just in the rear then the fluid will naturally move toward the front of the car and away from the fill hole. This would have the perception of not being full when it really is it the car was level. If it's on a lift then it's as level as it can be and just needs a little more fluid.
Old Feb 22, 2021 | 09:58 PM
Avanti's Avatar
Avanti
Yeah, just top it off appropriately and drive on. (be sure it's level when you do)
Old Feb 23, 2021 | 08:58 AM
javenius's Avatar
javenius
I drained mine at 1000 miles per the dealer's recommendation. I drained 74 oz and got 85 oz in. You should be fine.
Old Feb 23, 2021 | 12:59 PM
JMII's Avatar
JMII
I drained out 2.75 quarts and got 3 quarts back in with the car level. Many have reported to be about 0.5 quarts low from the factory.
Old May 29, 2021 | 07:04 PM
ValenciaOrange's Avatar
ValenciaOrange
I’m sorry to read this. Going for an oil change and now you have a major problem. You will read lots of advise and opinions on this site. Some people will sympathize with you, and others will tell you you might have not done the right thing.
It hurts when you have a problem and try to figure out how to get it resolved. Your problem won’t be solved over night. It will take time. You will get this problem taken care of. Hopefully it doesn’t cost you a lot of money.
To diff fluid
