VVT delete?
Old Jun 16, 2021 | 05:12 AM
JIMS SVT's Avatar
JIMS SVT
Default VVT delete?
Has my one done a vvt delete with the stock LT1 camshaft? Is it possible or do you have to jump to a aftermarket cam?
Old Jun 17, 2021 | 08:36 PM
4GS7's Avatar
4GS7
Are you looking to disable or fully delete?
The LT1 cam has different lobe profiles for the cylinders that deactivate, so you will need to change your cam if you intend to fully delete. I believe you have to use a factory LT5/ZR1 cam if you want to stay with the stock LT1 profile. No matter what, you will need a tune.
https://www.lsxceleration.com/chevro...haft-12664572/
Old Jun 17, 2021 | 09:09 PM
JIMS SVT's Avatar
JIMS SVT
In the process of doing a full custom twin turbo kit now. He wants to get the bugs worked out on the stock motor then swap in a built unit. It would be nice if I could go ahead and delete the vvt and bulged front cover without swapping the cam. LME has a nice kit and they said it can be done as long as you tunes for it afterwards.
Old Jun 20, 2021 | 08:29 PM
Avanti's Avatar
Avanti
I wondered what "WT" was... duh; MY bad!
To VVT delete?
