Power source
Old Aug 29, 2022 | 12:29 PM
Corvette-Dan's Avatar
Corvette-Dan
Default Power source
Can I remove this nut briefly without killing power?
Old Aug 29, 2022 | 01:33 PM
Maxpowers's Avatar
Maxpowers
I believe this is only used as a (+) for charging but im not certain.
Old Aug 29, 2022 | 06:14 PM
Corvette-Dan
I thought I heard somewhere that it was always hot.
Old Aug 29, 2022 | 08:12 PM
RonC7's Avatar
RonC7
That nut is always hot - fed from the 350 amp fuse on top of the battery.
From reports the nut is hard to remove without breaking the fuse box.
Why not slip a ring lug over the stud and add another nut? Be sure to fuse your new circuit and use appropriate size wiring.
Ron
Old Aug 29, 2022 | 09:43 PM
Corvette-Dan
Ron
I think I'll go this route. I have an in line fuse, 20 amp, that I will add a ring lug too. That wire is thick enough for my use. Only going to draw a couple of amps off of the nut. Do you know the thread size of the stud?
Old Aug 30, 2022 | 09:19 AM
RonC7's Avatar
RonC7
No, I don't know the size except it is likely metric. You my just have to try a few different nuts and find one that fits.
It would be a good idea to disconnect the battery cables if you are going to be messing around the stud very much.
Ron
To Power source
