2014 C7 DTC Code Help!
Old Oct 5, 2022 | 02:21 PM
byte_me's Avatar
byte_me
Default 2014 C7 DTC Code Help!
Issue resolved with OEM battery replacement!
Old Oct 5, 2022 | 02:33 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Since you broke the black wire and repaied it, maybe all that is required is to remove the negative lead from the battery, wait a couple of minutes and then plop it back down quickly and firmly and tighten it up. Reset the entire brain of the car and see if that doesn't get the codes to clear. Think Alt-Ctrl-Del to the car.
Elmer
Old Oct 5, 2022 | 02:53 PM
byte_me's Avatar
byte_me
Elmer
Thanks Elmer, I was hoping that would fix it as well and I tried that after fixing it.
Old Oct 6, 2022 | 05:08 PM
Bill Dearborn's Avatar
Bill Dearborn
When the battery is fully charged the instrument panel voltmeter should read 12.8 volts with the engine running. If not fully charged the voltage can vary quite a bit as the electrical load changes until the battery finally reaches its fully charged state. With a 12.6 Volt reading when the engine is off you may have a somewhat discharged battery. The first thing I would do is use a good battery charger (not a maintainer) to charge the battery, then disconnect the ground cable for a period of one minute to reset any codes and then see what happens. Remember U Codes usually mean one module temporarily lost communication with another module on a bus. If there are a lot of them that usually means the system voltage is too low. Here some info on U Codes and what they may or may not mean:
Bill
Old Oct 7, 2022 | 01:36 PM
byte_me's Avatar
byte_me
Bill
Thank you, Bill (as always!)
To 2014 C7 DTC Code Help!
