AC/Heater Issues
Old Mar 7, 2023 | 03:43 PM
calagna2017's Avatar
calagna2017
Cruising
Default AC/Heater Issues
I have a 15 C7. For the last year I have been having issues with AC and heater. The dealership literally replaced every part. $4000 later…same thing. It’s intermittent. One day the AC and heater will work, the next it does not. It will turn off and on during a car ride. No codes, every time a bring it to the dealership, it’s working so they can’t trouble shoot it, they make guesses and charge me each time. I tried resetting the factor setting. I tried to turn off and on the auto defrost mode. HELP!
Old Mar 7, 2023 | 05:11 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
I'm having issues with my 16. Intermittent blower motor and not blowing out the vents properly. I dropped it if at the dealer yesterday. They are replacing the blend door actuator. The door broke. They are also replacing my blower motor. They had to remove the complete dash out to get to the blend door. They are saying 14 hours in labor. Suppose to get it back Friday. Good luck to you. I feel your frustration..
Old Mar 7, 2023 | 05:14 PM
calagna2017
Cruising
@CorvetteMike2004 Did both…worked for a minute and started the same thing. Hopefully you’re not having the same issue.
Old Mar 7, 2023 | 05:54 PM
calagna2017
Cruising
@CorvetteMike2004 also ask for your old parts back because if it’s a situation like mine, they won’t give you your money back unless you prove it wasn’t those parts
Old Mar 7, 2023 | 05:59 PM
CorvetteMike2024
Corvette Enthusiast
So far its being covered by my warranty. Sending a warranty adjuster out tomorrow to authorize digging deeper into the dash. Parts are in Michigan. Hoping to have it back next week.
Old Mar 7, 2023 | 07:56 PM
charliebrown266's Avatar
charliebrown266
not sure this is your problem but when i bought my 2015 Z06 i had problems with heater/ac not working intermittenly not working and there tech bulletin on it and they reflashed the HVAC and never had the problem agian
Old Mar 7, 2023 | 07:59 PM
calagna2017
Cruising
@charliebrown266 tried that, didn’t work. It was a non dealership that did it so maybe I should try the dealer?
Old Mar 7, 2023 | 10:43 PM
Has to be extremely frustrating to have an issue that only acts up occasionally thereby making a repair hard for the dealership to accomplish. Best of luck getting this fixed without having to spend a lot more on parts/labor that may or may not be necessary.
Old Mar 8, 2023 | 10:43 PM
jdaniels138's Avatar
jdaniels138
Veteran: Marine Corps
Do you drive your car often? I've also had work done on mine. I don't daily drive mine.
I wonder if those that frequently use their cars see less issues with their A/C's. And if not using them often is part of the problem. Just a theory. I'd like to hear from the daily drivers. Also, if those with other GM vehicles see similar issues.
/JD
Old Mar 8, 2023 | 10:51 PM
CorvetteMike2024
Corvette Enthusiast
/JD
Mine is my daily driver. Hopefully I get my car back next week.
Old Mar 9, 2023 | 01:03 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Intermittents are difficult to diagnose…they should not replace parts if they can’t reproduce your concern !!…I’d get my parts and money back and get your car out of that dealership…find a diagnostic shop !!…if they replaced parts it’s probably an electrical issue…better yet an auto electric shop would be better for you !!
Old Mar 9, 2023 | 07:33 PM
CorvetteMike2024
Corvette Enthusiast
Thankfully my warranty is paying 100% of the repairs to get my corvette fixed. Hoping to get the car back Monday.
Old Mar 12, 2023 | 04:17 PM
Bill Dearborn's Avatar
Bill Dearborn
If its working when you start to take it to the dealership then call them and cancel your appointment. If it ain't broke they can't fix it.
Bill
Old Mar 17, 2023 | 04:20 PM
AmmoVet's Avatar
AmmoVet
Try this posting. It helped me get mine working as I had this issue. Wire was either loose or fretting (corrosion), simply unplugged and replugged and it worked and is still working since last summer.
https://www.corvetteforum.com/forums...t-working.html
To AC/Heater Issues
