Cam install supporting mods
Old Jun 3, 2023 | 05:30 PM
elaguna21's Avatar
elaguna21
4th Gear
Default Cam install supporting mods
Hi guys,
I'm looking to do a cam install soon, im looking to go boost after and i will be on stock converter so not a huge cam not sure if that makes a difference.
What are all the necessary and recommended supporting mods to get for a cam? new valvetrain stuff right? new oil pump? even if its things that arent necessary but are safer to do i will do them
(Its on a base LT1 C7)
Old Jun 3, 2023 | 08:33 PM
JosephMingle's Avatar
JosephMingle
Sub'd... boosted already and still thinking that lope would be nice.
Old Jun 3, 2023 | 08:42 PM
9sec's Avatar
9sec
dod/afm delete, lifters, springs,pushrods,trunion kit, vvt delete with billet cover, c5r timing chain and bolt, billet valley pan, katech oil pump is a nice addition but pricey. if you keep oem pump you need to use lock out tools so its replaced in the same position to prevent oil starvation. fueling is another issue to deal with
Old Jun 3, 2023 | 09:32 PM
elaguna21's Avatar
elaguna21
4th Gear
Got it. Stock fuel system should be fine until i go boost though no?
Old Jun 4, 2023 | 09:26 AM
9sec's Avatar
9sec
on pump 93 possibly. the answer would be determined during the tune to see if the dfi injectors are dropping psi at high rpm.
To Cam install supporting mods
