Key FOB Issue
Old Jun 9, 2023 | 05:18 PM
murf257's Avatar
murf257
Default Key FOB Issue
When I purchased my 2018 Z06 used, it only had one FOB. The dealer ordered a second one for me but it now comes up as FOB #3 and I can not get the previous seat to work. Any suggestions?
Old Jun 9, 2023 | 06:34 PM
RonC7's Avatar
RonC7
The dealer ADDED a fob which assigns the next fob number, in this case #3. Memory is only linked to #1 and #2.
You need to use the LONG method described in C7 General | Sticky Threads or "Programming without Two Recognized Transmitters" in your owner's manual. This also unpairs the missing fob. You can download a pdf version of your manual in C7 General | Sticky Threads.
The dealer should also have provided a cut metal key. If not, ask them for the key code #. There is a vendor on ebay that will cut you a metal blade key from the key code or photos...
Ron
Old Jun 9, 2023 | 08:56 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Ron nailed it.
Elmer
Old Jun 9, 2023 | 09:05 PM
murf257's Avatar
murf257
Default FOB Issue
Thank you very much!
To Key FOB Issue
