Help with new key programming
Old Jun 15, 2023 | 01:43 PM
laserdude2215's Avatar
laserdude2215
Originally Posted by RonC7
At some time they had a fob - needed to get the dash display shown in pictures.
No fob required. Just open the door.
Old Jun 15, 2023 | 02:23 PM
KirillG88's Avatar
KirillG88
Wow, that is quite a bit of damage. That is a lot to take on even if you have a good source for parts and technical advice. I'm sure you realize that the Corvette is as much a computer network on wheels as a mechanical device.
I wish you lots of luck!
Keep us posted on your progress.
Ron
Realize . To be honest, i don't have a good source for parts, most of them i order from the US, Corvette is quite a rare car here, so parts cost x3, but there are some good mechanics and workshops dedicated to the Corvette community, also i really hope the damage is not as bad as it looks, overall it looks fine ( i guess ), just missing some body parts and of course suspension damage.
Thanks, i guess I'll need that luck and of course, I'll keep posted (also will update in the Collector's Edition thread, i have the #309 btw)
@laserdude2215 Exactly .
Old Jun 15, 2023 | 09:46 PM
laserdude2215
I hope they left you a place to insert the key.
Old Jun 15, 2023 | 10:36 PM
laserdude2215
Here's some good news for you. With the bumper cover missing, you should have access to the wires that go to the key cylinder switch. Just short them together five times in ten seconds and you will be on your way to programming the car to recognize your new fob. No key required!
Old Jun 15, 2023 | 11:22 PM
RonC7's Avatar
RonC7
The above is true if the battery is not dead when the car gets to Poland. It would be a good idea to pop the hatch and hood now before shipment and keep a window down if at all possible.
It is not clear from the pictures if the rear hatch release cable from the key cylinder is accessible to open the hatch. If not and a window is down so you can enter the car through a door, you can open the hood and connect 12 v at the front fuse block or crawl into the rear compartment and connect 12 v at the aux plug on the inside right corner. If not, you will need to connect 12 V at the starter so you can open the hatch and access the battery. You should only attempt to charge the battery at the battery terminals.
A quick test on my 2019 GS verifies that the electric hatch release buttons on the dash and above the license plate will work without a key fob in / near the car (car was unlocked by a fob 20 feet away).
Lots of unknowns until you get hands on the car.
Ron
Old Jun 16, 2023 | 03:50 PM
KirillG88's Avatar
KirillG88
Wow that's a piece of an idea. I'll try this. Cause I've got an answer from a Polish dealer that they are not able to cut the blade unless i have at least 1 key, even though by the VIN :/ , this is strange as hell.
On the other hand, I've got a friend ....that have another friend that can program the key fob without actually being near the car, he just needs the VIN code, and the cost is 300$. Maybe its a good deal.
@RonC7 Yeap , the window will be kept open. But there is a good chance that the battery will die. Anyway, thanks for advice
Old Jun 16, 2023 | 04:29 PM
laserdude2215
THE KEY FOB DOES NOT GET PROGRAMMED! The car gets programmed. Do not get scammed.
Old Jun 16, 2023 | 04:53 PM
MBrianB's Avatar
MBrianB
To program the RKE fob to the car, you have to be in the car. The VIN has nothing to do with the RKE fob. I just programmed two new fob's to my car.
The VIN is what you need to get the metal key made. However, if from your picture the lock mechanism is gone to begin with you will probably need to get new lock and keys.
Old Jun 17, 2023 | 12:44 PM
KirillG88's Avatar
KirillG88
Dang , there is something in what u say , that's strange, he says it will work 100%, not a scam for sure, that's someone i know very well, otherwise, he will return the money. This guy is doing keys for all cars , i mean this is not his first time. But anyway, I'll try all options i have
Old Jun 17, 2023 | 12:46 PM
KirillG88's Avatar
KirillG88
Yeap . That is what I'm aware of as well , that i need to be in the car in order to program it ..... but i'll give this guy a try, maybe he knows something
Old Jun 17, 2023 | 02:04 PM
RonC7's Avatar
RonC7
There is nothing to program or configure in the fob. All pairing information is stored in the car. With the car powered up and the fobs available you can plug into the diagnostic port with the proper software and pair the fobs. But - the programming tool & software, car, and fobs must be in the same place.
Ron
Old Jun 17, 2023 | 02:20 PM
KirillG88's Avatar
KirillG88
Ron
Thanks Ron , roger that .
Old Jun 20, 2023 | 11:51 AM
  #33
KirillG88's Avatar
KirillG88
You were absolutely right guys. This guy wasn't aware that the car is in Poland, this guy is from Ukraine and he thought that the car is in Ukraine and we will come to the program it. Said as well definitely that the key cannot be programmed, only have to be inside the car. I'll search for someone in Poland maybe that can do it.
Old Jun 20, 2023 | 12:52 PM
  #34
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
TO program a FOB without a metal key you need to have a special tool that dealers have. THey are expensive.
Once you have the metal key cut using the VIN number, you then can program the car to recognize your FOBs to work the car.
The keyhole at the rear of the car is turned 5 times quickly to start the process. YOU MUST NOT have any FOBS, working or new, near the car.
You would use the FOB programming we linked you to earlier to program the car and you MUST use the long program.
When you are finished, you will have FOBS 1 & 2 (or more) for the car.
Elmer
Link to programming:
http://forums.corvetteforum.com/c7-g...s-and-rke.html
