Help with new key programming
Old Jun 15, 2023 | 03:58 AM
KirillG88's Avatar
KirillG88
Default Help with new key programming
Hi there , i've recently found information in the forum about pairing a new key if i have an existing one. But how do i pair a completely new key ? According to the manual, i need to turn the key a couple of times at the trunk or something and the car goes to pairing mode, but again .... how can i do it if i have a brand new key with an uncut key blade.
Also please advise if this key fits my car (Grand Sport Coupe 2017 3LT) ?
Thanks for the answers
Old Jun 15, 2023 | 10:46 AM
laserdude2215's Avatar
laserdude2215
If you have an A8 automatic, that is the correct key.
Certainly you have one working key? Just use that one to turn the trunk lock.
Old Jun 15, 2023 | 10:54 AM
KirillG88's Avatar
KirillG88
That's what I'm talking about :| I bought the car at an auction and the key is missing
I have got the key from the link above, now I need to understand how I'm going to pair it with the car
Old Jun 15, 2023 | 11:23 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
your going to need someone to program it for you with a tech 2. And you’ll need a dealer/co to cut the new key for you with the vin number. Maybe a locksmith can do it too.
Old Jun 15, 2023 | 11:34 AM
laserdude2215
Why would you buy a car with zero keys? Let me guess. It's wrecked.
Tech 2 doesn't work for a C7. You need to find a dealer with access to SPS. Or find a dealer or locksmith who can cut the key for you. You will need proof of ownership and proof of identity.
Old Jun 15, 2023 | 11:36 AM
MBrianB's Avatar
MBrianB
You will need the metal key for the trunk to start the programming. That is only available from a dealer and is based on the VIN#.
Once you have the metal trunk key you can program new RKE remotes. Program all new remotes or reprogram old remotes, it doesn't matter.
Old Jun 15, 2023 | 11:44 AM
RonC7's Avatar
RonC7
You are confusing us when you say KEY.
- Do you have a working fob?
- Is there a cut metal blade key in the fob?
You need to use the LONG method described in C7 General | Sticky Threads RKE/FOB item or "Programming without Two Recognized Transmitters" in your owner's manual. This also unpairs the missing fob.
You can download a pdf version of your manual in C7 General | Sticky Threads. You must have a cut metal key to pair fobs to the car using procedures in the Owner's manual or RKE/FOB thread. Otherwise a dealer or maybe a locksmith can pair the fob. You will still need a metal key for access if the battery is dead. A dealer parts department should be able to look up the key code based on your VIN and cut a key if you don't have one.
Download Owner's manual and Infotainment manuals from links here:
https://www.corvetteforum.com/forums...cking-etc.html
RKE / FOB thread:
https://www.corvetteforum.com/forums...uncements.html
Ron
Old Jun 15, 2023 | 11:48 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
If you don't have the key, get one. Then have the dealer cut it for your VIN. Then use the key in the trunk key hole to do the long program and you will end up with 2 FOBs that will have memory.
Elmer
Old Jun 15, 2023 | 12:02 PM
KirillG88's Avatar
KirillG88
Thanks for the manuals!
RKE / FOB thread:
Ron
Sorry for the confusion, no i don't have both, i don't have a working fob, nor the cut key. Only brand new fob with uncut blade.
ptroxx's Avatar
ptroxx
you didn’t read through the post. No key or fob. Got car at auction
RKE / FOB thread:
Ron
he lives in Poland. I don’t think they have a Chevy dealer on every corner like in the states.if they have one at all.
Elmer
Old Jun 15, 2023 | 12:08 PM
KirillG88's Avatar
KirillG88
he lives in Poland. I don’t think they have a Chevy dealer on every corner like in the States.if they have one at all.
Exactly was about the write about it , i don't even think we have Chevy dealer , i tried to find one now and i think we don't have one. I have a family member living in Quincy and there is a dealer just 7 minutes from her. Any chance they can cut the key? if ill provide all the ownership docs ?
Old Jun 15, 2023 | 12:11 PM
ptroxx's Avatar
ptroxx
yes there’s a chance. As long as she has all the documentation.
also. If you have a good locksmith. They may be able to cut the key with the vin number. I’d check that first
Old Jun 15, 2023 | 12:12 PM
MBrianB's Avatar
MBrianB
https://www.chevroleteurope.com/cont...t/poland1.html
Old Jun 15, 2023 | 12:22 PM
RonC7's Avatar
RonC7
Was the car wrecked? How did they even transport it without a fob? The metal key will get you into the rear hatch area, then there is a cable to pull that will open the driver's door. Obviously, you need battery power to pair a fob or do anything else.
GL
Ron
Old Jun 15, 2023 | 12:27 PM
ptroxx's Avatar
ptroxx
GL
Ron
you can see the car in his aviator.
my bet is it was a repo.
so no keys.
I’m sure it wasn’t easy to transport.
he needs a good locksmith to cut the blank he has with the vin.
Old Jun 15, 2023 | 12:40 PM
KirillG88's Avatar
KirillG88
so no keys.
No no , its a random vette on my avatar . My vette is currently on its way from the US in a container
No idea how they transport it, but by the photos that I've got from the port, the driver's window is half open, so they have access to it. My guess is that the key was lost by the auction owner.
And yes @RonC7 , the car is after collision, here are photos from the auction
Old Jun 15, 2023 | 12:44 PM
ptroxx's Avatar
ptroxx
ahhh. Ok. Not a bad price. About 20k is I think if I did it right. Lol.
id call a few locksmiths. They should be able to cut the key with the vin.
To Help with new key programming
Old Jun 15, 2023 | 12:50 PM
KirillG88's Avatar
KirillG88
Just noted the link from @MBrianB (Thanks) and found a dealer in Warszaw, sent them a query if they can do it if not I'll look for locksmiths
Old Jun 15, 2023 | 01:06 PM
RonC7's Avatar
RonC7
Wow, that is quite a bit of damage. That is a lot to take on even if you have a good source for parts and technical advice. I'm sure you realize that the Corvette is as much a computer network on wheels as a mechanical device.
At some time they had a fob - needed to get the dash display shown in pictures.
I wish you lots of luck!
Keep us posted on your progress.
Ron
Old Jun 15, 2023 | 01:42 PM
ptroxx's Avatar
ptroxx
Ron
the add says key missing on the bottom not sure how that pic was taken with the screen
