Need help with my Corvette
Old Sep 24, 2023 | 12:56 PM
Derek2534's Avatar
Derek2534
Default Need help with my Corvette
I have a 2016 Z51 M7. I took it to mutiple GM worthless mechanics for issues involving grinding when shifting from 1-2 2-3. First thing they did was replace the clutch. Now a year later I have grinding in all the gears. I'm hearing a click sound and werid vibration sounds when I'm driving on the highways that goes away when I slam the gas. Now the biggest issue I am noticing is that I can feeling some bad back and forth motions if I'm in first and give it gas an let go of the gas. Also downshift is the worse. Driving around parking lots is painful because it is terrible. Can anyone give me advice. I'm done with GM mechanics. They all suck IMHO.
Very Respectfully,
Derek
Old Sep 24, 2023 | 01:07 PM
Flattman's Avatar
Flattman
Have you tried to realign the shifter box? There is a TSB on it:
https://www.corvetteforum.com/forums...adjustment.pdf
File Type: pdf
Old Sep 24, 2023 | 01:10 PM
Derek2534's Avatar
Derek2534
Unfortunately, yeah, when it first starting to act up they did that twice.
Old Sep 24, 2023 | 04:26 PM
Dads2kconvertible's Avatar
Dads2kconvertible
How many miles on it?
Is it possible to find an experienced transmission person in Russia?
Old Sep 24, 2023 | 04:49 PM
Derek2534's Avatar
Derek2534
Just padded 50k miles. I'm almost positive Russian mechanics are better.
Old Sep 24, 2023 | 08:27 PM
Dads2kconvertible
Interesting but not what I asked you.
I'd try to find someone experienced with transmissions. Corvette/sports car shop if possible.
I'm guessing GM products in Russia are fairly uncommon so mechanics don't have much experience with them. Parts may be hard to get too.
There are bound to be some speed shops around.
Good luck
Old Sep 24, 2023 | 08:51 PM
Donwuan's Avatar
Donwuan
If RussIan mechanics are better why can't they fix it?
Old Sep 24, 2023 | 09:24 PM
Derek2534's Avatar
Derek2534
Good luck
What are you even talking about? I asked a question and you went full stupid. Don't throw your hip out.
Old Sep 24, 2023 | 09:40 PM
Moving to C7 Tech for some assistance.
Old Sep 24, 2023 | 11:27 PM
Persayis's Avatar
Persayis
Buy a used M7 transmission in working order. Have a shop install the transmission for you. This all gets your car back on the road as soon as possible.
Take the broken one home, dissemble and inspect it on your own. Make a project out of it. Build or buy special tools as needed. Then you'll know about the M7 transmission and one of the ways it goes bad. Source replacement parts and repair it. Not only will you have a spare but you'll be an M7 expert and probably know what you're hearing the next time one acts up.
Old Sep 25, 2023 | 10:32 PM
Avanti's Avatar
Avanti
Derek... people here are just trying to help you with your issue, and that in an environment where your car cannot be all that common (heck, there are no others in the town I live in here in the States). Lighten-up. And, all the best fixing your Vette.
Old Sep 29, 2023 | 07:36 PM
CraigStu's Avatar
CraigStu
Well I am done with this thread.
To Need help with my Corvette
