X pipe.
Old Nov 3, 2023 | 12:24 PM
kodpkd's Avatar
kodpkd
Default X pipe.
I have a stock 2014 1LT. I want to add the X pipe. Can you tell me about the good, bad and ugly of adding an aftermarket X Pipe? I see them for about $250 to $350.
Old Nov 3, 2023 | 12:39 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Lose secondary CATs
Allows for more sound to exit pipes.
Easy to do, just lots of bolts to take R/R.
Elmer
Old Nov 3, 2023 | 12:48 PM
kodpkd's Avatar
kodpkd
I keep reading they are not available without the CATs. Do all the X pipes eliminate the center CATs?
Old Nov 3, 2023 | 02:48 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
I recently installed the EOS double helix x-pipe (link below). It eliminates the secondary set of cats. Low cost, but excellent quality. And installation was pretty easy.
EOS X-Pipe
It isn't really any louder, just a "throatier" tone. Maybe a little louder right at cold start-up, but idle is not much different, at least to my old-man hearing.
To me it was only worth it because the cost was low and I enjoy "tinkering" with my Corvette. Knowing what I know now, I would never spend the money for the higher priced versions. Not enough benefit for the buck!
Old Nov 3, 2023 | 07:43 PM
ICONIC7's Avatar
ICONIC7
2023 C7 of the Year Finalist - Modified
The bigger exhaust companies used to sell X-pipes that eliminated the secondary cats. They are no longer allowed to sell them due to EPA rules/regs. EOS as mentioned above seems to be one of the few still selling them without the cats.
Old Nov 3, 2023 | 07:45 PM
kodpkd's Avatar
kodpkd
This ebay add says it's mounted behind the CAT's. What CAT's are they talking about? The main CAT's or the secondary ones connected to the X pipe. One of the pictures shows very small CAT's on the X pipe, other pictures don't have it.
https://www.ebay.com/itm/32453625982...Bk9SR77u-evyYg
Looking at the BORA install directions, they cut the secondary CAT's off and mount them to the X pipe. Not what I am looking for..
Old Nov 4, 2023 | 08:53 AM
kodpkd's Avatar
kodpkd
What doesn't make any sense with the new X pipes. You still have the secondary CAT's with restrictions at the front of the new pipe and the same size pipe at the rear of the X pipe exiting the back of the car, so what has been accomplished? Nothing!
Plus,,,,, they have you destroy your original X pipe by cutting off the old secondary CAT's. I want the old X pipe if I want to go back to original.
Old Nov 4, 2023 | 09:51 AM
ICONIC7's Avatar
ICONIC7
It does look like they are keeping the secondary cats on the Ebay link you attached. And you're right, there's no point in buying a new x-pipe if it only installs behind the cats.
Your best bet is to keep checking the forum's here for someone selling a used one that deletes the secondary cats. They do pop up from time to time.
Old Nov 4, 2023 | 09:59 AM
fuzzy03cls's Avatar
fuzzy03cls
Other then some sound increase, tone differences, any real world power gains or other benefit? Is there a reason to want to dump the cats?
Old Nov 4, 2023 | 10:18 AM
kodpkd's Avatar
kodpkd
My original thought,,, better flow, better sound, maybe a bit more power.
Old Nov 4, 2023 | 08:36 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
This ebay add is the same EOS X-pipe I purchased direct from Extreme Online Store (EOS), located at the link I provided in my post above. This pipe is a double helix x-pipe that bolts right up to the existing exhaust where you remove the stock x-pipe. The stock x-pipe has the secondary cats attached and will be eliminated when you install this EOS x-pipe.
Old Nov 4, 2023 | 08:49 PM
kodpkd's Avatar
kodpkd
I looked at that X-pipe, it says on their web site that it keep the cat converters. "Cut N Clamp X-Pipe retains factory catalytic converters" "The EOS Corvette C7 Cat-Connect X-Pipe mounts directly behind the stock catalytic converters" I wish that wasn't the case.
Old Nov 5, 2023 | 10:11 AM
kodpkd's Avatar
kodpkd
I still can't figure out how the EOS X-pipe connects. They say just bolt on. So what is it? Cut the old secondary cats and install them with the X-pipe or just bolt it on?
EDIT:
I finely found the picture I was looking for. Clearly the X-pipe is long enough to eliminate the sec CAT's. Ordered from Ebay $269 with free shipping.
Old Nov 5, 2023 | 11:42 AM
9sec's Avatar
9sec
EDIT:
it replaces the entire oem xpipe. you lose the oem secondary cats. I have this exact setup and also added the eos catless downpipes to have a full 3" system from the manifolds to the catback mufflers and zero cats. you dont cut any cats you remove them
Old Nov 5, 2023 | 11:06 PM
I8URRICE's Avatar
I8URRICE
EDIT:
It is a direct bolt on, you can reuse the donut gaskets from the Original X Pipe or purchase new ones. On the rear of the X pipe just sleeve the Clamp over the pipe on the muffler and bolt together.
Old Nov 6, 2023 | 06:17 AM
mdformula350's Avatar
mdformula350
eos is direct bolt on, many have bought that one with no issue.
they made it to kind of present the idea it can keep cats with much work.
speed engineering has one as well.
https://speed-engineering.com/produc...t1-lt4-engines
thats all 1 piece, which is even more a plus.
there is no bad or ugly for a catless xpipe because 2 less things to go bad on especially if you track the car.
you get a tad more performance and sound.
Old Nov 6, 2023 | 08:29 AM
kodpkd's Avatar
kodpkd
I ordered the EOS from Ebay, the picture shows it comes with the donut gaskets and it's free shipping. It should be here this week.
This pipe comes in two pieces, I figured I would measure the original pipe and bolt the two together the same length.
EDIT:
Good suggestion MacA1979,,,, I think I will try with the Front bracket facing up to make it easier to bolt the clamps.
I also have the Quickjack and love it. It stays on the floor and I can park the vet over it.
To X pipe.
Old Nov 6, 2023 | 08:46 AM
MacA1979's Avatar
MacA1979
Always Shiftin'
If you decide to move forward with the EOS X-pipe, I would recommend reviewing the thread I have linked below...
https://www.corvetteforum.com/forums...ispreloading=1
The two piece assembly creates some additional installation challenges, but isn't a real issue. MA Z06 had a nice write-up on the thread and I included some information that might also be helpful. Read all the way to the end.
Don't hesitate to PM me if you have any questions. I will be happy to help!
Old Nov 6, 2023 | 09:52 AM
kodpkd's Avatar
kodpkd
Old Nov 6, 2023 | 10:10 AM
Ex_F-Body_Enthusiast's Avatar
After some research I determined that a 1-piece design was easier to install and overall a better solution, so I went with the 1-piece Speed Engineering double helix X-pipe a few months back for only $249.00+shipping: Speed Engineering C7 Double Helix X-Pipe
Excellent quality, perfect fitment, highly recommended!
