Misfire
Old Nov 3, 2023 | 08:00 PM
c7jaay's Avatar
c7jaay
8th Gear
Default Misfire
I got a 2015 corvette c7 with 20k miles I recently installed longtube headers and an x pipe on the car and everything was working out fine. Just two days after the install and driving the car I got a flashing check engine light with reduced engine power and stabilitrak light. I was only 5 min away from home so got it home and didn’t drive the car after… I replaced the spark plugs and wires to see if that would help and the car still keeps misfiring.. only codes I’m getting are P0443,P0458,P06DA
any idea what it could be ? I’m tired of just throwing money into it and getting no results.
Old Nov 4, 2023 | 07:56 AM
Tinkertech's Avatar
Tinkertech
Exhaust leak or rough handling of the install resulting in a wiring problem.
Old Nov 4, 2023 | 09:14 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Or your O2 sensor wiring got to close to the headers
Elmer
Old Nov 4, 2023 | 04:52 PM
c7jaay's Avatar
c7jaay
8th Gear
Elmer
I replaced both o2 sensors yesterday
Old Nov 4, 2023 | 07:45 PM
Pshoe's Avatar
Pshoe
My misffire was a burnt center electrode on 1 spark plug.
Old Nov 4, 2023 | 10:13 PM
Racer1735's Avatar
Racer1735
Headers....x-pipe. Did you get a tune? You probably should as you've leaned it out. The ECM will compensate some.
To Misfire
