Fuel-It Blue Tooth module
Old Aug 2, 2024 | 08:07 AM
crewchief25's Avatar
crewchief25
Default Fuel-It Blue Tooth module
I bought a Fuel-It blue tooth module, plugged it to my DSX flex fuel sensor using the DSX wire harness and it will not work. Burger Motorsports is telling me it is not compatible to the DSX product. I know some of you are using this blue tooth mod from Fuel it. What am I doing wrong?
Old Aug 2, 2024 | 02:03 PM
Travlee's Avatar
Travlee
i know i bought the wrong one initially
this is the one i ordered about 3 years ago
Old Aug 2, 2024 | 03:41 PM
crewchief25
Thats the same one I bought. Attached is my email, there was no mention of the wrong part or fix. I ordered what their customer service chatbot told me to order.
Old Aug 2, 2024 | 03:49 PM
Travlee's Avatar
Travlee
they are FOS... i have the dsx kit and it works. i know when i ordered they had different options, and per @Internets_Ninja i needed the 50-150hZ raw... which looks like the universal one does now
Old Aug 2, 2024 | 03:53 PM
Travlee's Avatar
Travlee
https://fuel-it.com/products/fuel-it...-fuel-analyzer
Old Aug 2, 2024 | 04:05 PM
Travlee's Avatar
Travlee
So if it's same....let's check the obvious. I once tried to check mine and it wouldn't connect, unplugged it for a bit...still wouldn't, but then I noticed Bluetooth was off on my phone. Double check that
Old Aug 2, 2024 | 04:11 PM
crewchief25
I had no connectivity. They had me direct wire it to the battery and still no connectivity. I doubled and triple checked that my Bluetooth was on.
Did you use the DSX wire harness or the harness with Fuel it device? I dont know if it would make a difference
Old Aug 2, 2024 | 04:17 PM
Travlee's Avatar
Travlee
I just plugged it in inline.... give me 15 or so and I will snap a pic. It's possible it's a bad unit
Old Aug 2, 2024 | 04:29 PM
Travlee's Avatar
Travlee
So...the plug that would go to dsx unit, goes to pigtail of sensor, sensor to dsx (it's 105 degrees and didn't feel like lifting up the cover)
Old Aug 2, 2024 | 05:03 PM
crewchief25
I really expected it to be a 10 minute simple solution. They didn't want it back, which surprised me. But telling me its not compatible makes it that I question buying another.
Old Aug 2, 2024 | 05:09 PM
Travlee's Avatar
Travlee
Reach out to fuel-it directly.. when I get home let me see if I still have the wrong one.
Old Aug 2, 2024 | 05:24 PM
crewchief25
Fuel-it technical support, sales & order emails do not work any longer. I guess Burger Motorsports has bought them.
Old Aug 2, 2024 | 06:29 PM
Internets_Ninja's Avatar
Internets_Ninja
The module is super easy. On the new universal ones you have to go into the app on your phone and turn on the pass through signal to the ECU. It simply plugs inline with the flex fuel sensor. Donwnload the app and connect. We use them all of the time with the DSX flex fuel sensor.
Old Aug 2, 2024 | 07:58 PM
crewchief25
Do you use the DSX wire harness or the Fuel it harness? I personally don't see it would matter?
Old Aug 3, 2024 | 09:06 AM
Internets_Ninja
The fuel it blue tooth module doesn't have an extra harness. It simply plugs in-line with the flex fuel sensor.
Old Aug 3, 2024 | 09:33 AM
crewchief25
This is what they sent, minus the sensor.
Old Aug 3, 2024 | 10:02 AM
2001PewterWS6's Avatar
2001PewterWS6
Only plug in the inline part, mine came with the extra harness but isn't used. I had an issue with mine as well at first but I emailed them and got me straightened out. Works fine now.
To Fuel-It Blue Tooth module
Old Aug 3, 2024 | 10:23 AM
2001PewterWS6
Once you connect to your phone make sure the output mode is set to frequency under the settings
Old Aug 3, 2024 | 01:37 PM
crewchief25
Mine must be bad. I get P0178 code when I plug the fuel it sensor in
Old Aug 3, 2024 | 01:49 PM
Internets_Ninja
Or you haven't enabled the pass through feature in the app, which is required, or you won't get a signal to the ECU. It's been mentioned a couple of times in this thread already.
