Fuel-It Blue Tooth module
Old Aug 16, 2024 | 12:03 PM
  #41
Internets_Ninja's Avatar
Internets_Ninja
You should be able to connect to the module regardless. If the ECU is getting the signal then my idea will work. I bet if you fix your Bluetooth part, you will be able to read the content on your phone.
Old Aug 16, 2024 | 12:10 PM
  #42
crewchief25's Avatar
crewchief25
Ninja, were you able to connect bluetooth to your customers analyzer that didn't work last week?
Old Aug 16, 2024 | 03:05 PM
  #43
Internets_Ninja
yes, it connected and showed the ethanol properly, but it didn't pass the signal to the ECU so the ECU didn't know what the content was.
Old Aug 16, 2024 | 03:23 PM
  #44
crewchief25
Your work around idea would work for you then. I verified with VCM scanner my ethanol content is reading now. I think there is something else wrong with my analyzer besides not working like the old units. No matter what I do I can not connect. That's why BM was so quick to refund my money.
Old Aug 17, 2024 | 08:40 AM
  #45
Internets_Ninja
Sounds like a bad module or it wasn't getting any power passed to it.
Old Aug 17, 2024 | 01:02 PM
  #46
crewchief25
Yea, BM had me direct wire to the battery to see if I could connect and I still could not. So I'm on hold till someone finds a for sure work around or I will buy the Advanced Fuel Dynamics, FlexLink.
