Engine Design Software
Old Aug 17, 2024 | 10:30 AM
96GS#007's Avatar
96GS#007
Default Engine Design Software
Back in the day.....damn I'm getting old....there used to be a variety of engine design software packages. You could model bore, stroke, rod length, static and dynamic compression, ignition timing, all the cam specs, etc and come up with an engine design. It was great for not only peak power determination but also changing the shape of the hp and torque curves.
Does anyone know of something similar that exists in this day in age? Ideally it'd be for Gen V engines but I suspect that may be a bridge too far.
Old Aug 17, 2024 | 11:43 AM
Pshoe's Avatar
Pshoe
Try this.
Performance Trends
I have used an older version of this with great results.
If your input data is good the output to real world dyno results are very close.
Old Aug 17, 2024 | 03:34 PM
96GS#007's Avatar
96GS#007
Originally Posted by Pshoe
Try this.
Performance Trends
Exactly what I was looking for! Thank you!
Old Aug 17, 2024 | 06:40 PM
Very cool software that is available.
To Engine Design Software
