Return line / hosepinched
During my disassembly of my 2015 Z51 w/dry sump I pinched a return oil hose. Can anyone shoot me a part# so I can get that ordered. I’ve looked online but not too tech savvy.
Line is to the left just above surge tank. You can see that my gracefulness and patience left the building when I got to back plug🤬
It may be better to head to your nearest Chevy dealer to get the most accurate part number…even if not buying the part there they will help you…I do it all the time.
It's probably 5/16 or 3/8 diameter. It's just nylon tubing. Cut it off the barbs on the connectors and pick up some replacement tube and cut to length. Just measure the OD first to confirm what diameter you need. Local auto parts store might have it in stock. Otherwise Amazon.
https://a.co/d/9BZyMVn
