Oil
Old Nov 18, 2024 | 02:30 PM
C746490's Avatar
C746490
Default Oil
Where can I find 0w-40 mobile 1 dexos (sp) oil for my 2019 GS? All the oil that I have found does not have dexos on the label. I want to stock up on oil and filters.
Old Nov 18, 2024 | 02:45 PM
RonC7's Avatar
RonC7
Internet search is your friend. Search for "Mobil 1 0W40." ESP is listed as Dexos Gen 2 and Supercar is Dexos R. Both flavors are OK. Some auto parts stores carry one or the other locally.
Ron
Old Nov 18, 2024 | 02:51 PM
Blackwater0323's Avatar
Blackwater0323
Amsoil 0W-40 Signature series exceeds the Dexos spec.
Old Nov 18, 2024 | 03:04 PM
Bill Dearborn's Avatar
Bill Dearborn
I found it on Amazon. They sell it in boxes of 6 quarts for about $59.
Bill
Old Nov 18, 2024 | 03:29 PM
Pshoe's Avatar
Pshoe
I had been getting mine from Speedway motors. 12 qts and a filter as a package.
Since then I've been using 15-50. I do very few street miles and when I do I wait till the oil temp is 150+ before I let it see any real RPM or load.
I tend to change it after every 2 or 3 events and the heavier oil is less than half the cost.
Old Nov 18, 2024 | 07:41 PM
kodpkd's Avatar
kodpkd
WHY would you use 50 weight oil?????
Old Nov 18, 2024 | 07:52 PM
Pshoe's Avatar
Pshoe
15w50 was recommended for track use prior to the switch to 0w40 supercar oil.
my on-track oil temps run in the 270–280-degree range.
That's why.
Old Nov 18, 2024 | 08:20 PM
kodpkd's Avatar
kodpkd
That's why.
OH,,,,, I thought we were talking about 0W-40 supercar oil for normal cars.
Old Nov 20, 2024 | 09:27 AM
weathermaker's Avatar
weathermaker
Bill
Thats where I got it also.
Old Nov 20, 2024 | 03:59 PM
Dads2kconvertible's Avatar
Dads2kconvertible
I don't quite understand what you're saying Pshoe. You're using 50 weight because it was recommended in the past or because your oil temps run 270-280 range? If it's the temps, what benefit does a 50 weight oil provide that the 40 weight would not?
Old Nov 20, 2024 | 04:23 PM
Pshoe's Avatar
Pshoe
Here is an article explaining the generally accepted guidelines for oil viscosity.
K1 is a manufacture of cranks and connecting rods for reference.
Bearing Clearance And Oil Viscosity Explained | K1 Technologies
0w40 is kind of the sweet spot for the LT1/4 all around.
And I have used it. The 15w50 was recommended by GM for track use prior to 0w40 being available.
The economics are 54$ for 10 qts of 15w50 vs 110$ for 10 qts of supercar 0w40.
With the frequency I change fluids it adds up.
When I do occasionally drive on the street it's important to get the oil fully warmed up before giving it a go.
I'm not advocating anyone do this. It's what I do.
44,000 miles and counting.
Hope that helps
Old Nov 21, 2024 | 08:02 AM
Tinkertech's Avatar
Tinkertech
For:
Street: 5 - 30.
Limited Track: 0 - 40.
Heavy Track: 15 - 50.
Old Nov 21, 2024 | 02:20 PM
kodpkd's Avatar
kodpkd
OLD GM recommendation for C7,,,,, 5W-30 street
NEW GM recommendation for C7,,,,,0W-40 street
Race car recommendation for C7,,,,,,0W-40 or 15W-50.
Old Nov 21, 2024 | 03:15 PM
ZumZum's Avatar
ZumZum
Are these recommendations for all years of the C7 LT1 or are the new recommendations for later years of the LT1?
Old Nov 21, 2024 | 07:25 PM
kodpkd's Avatar
kodpkd
The recommendation is for all years. GM changed the recommendation. They recommend 0W-40 Mobil 1. They started recommending ESP oil but Mobil upgraded the ESP oil to Supercar oil. Now you can get 0W-40 Supercar oil.
Old Nov 23, 2024 | 11:37 AM
CraigStu's Avatar
CraigStu
I order from Summit. BTW the Supercar oil is available in 5-50 also if you want to go kind of halfway to 15-25. You still get the 5W for cold starts and also get all the 'Supercar' attributes which I don't think the 15-50 has. Summit shipping is free if you spend >$100 so I grab filters or cans of brake cleaner to bump my order if needed.
Old Nov 23, 2024 | 01:40 PM
kodpkd's Avatar
kodpkd
BUT 25 weight oil is way to thin. GM went from 30 weight to 40 weight for recommended oil.
5W,,,, doesn't stand for 5 weight.
To Oil
Old Nov 26, 2024 | 11:16 AM
CraigStu's Avatar
CraigStu
A jeez, a typo. Sorry. I meant to type 15-50.
Old Nov 26, 2024 | 01:22 PM
kodpkd's Avatar
kodpkd
Ok thanks.. So you use 50 weight oil for racing or your daily driver?
Old Nov 26, 2024 | 02:41 PM
helga203's Avatar
helga203
W stands for winter. It work with the chemical in the oil as it heats up it goes the weight. Don't ask how.
