Brake Caliper
Old May 1, 2025 | 06:03 PM
FRED HAMBLE's Avatar
FRED HAMBLE
Default Brake Caliper
Need to replace a brake caliper on my 19 GS. Dealer said I need to buy a new caliper. Don't they repair calipers anymore?? Anyone have a similar experience?
Fred
Old May 1, 2025 | 06:33 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Did you ask the dealership why it needs to be replaced ??…repair is .3 hours of labor and the caliper cost is listed below whether you have ceramic rotors or not…at that price you can see why they want to replace.
Old May 1, 2025 | 07:12 PM
Pshoe's Avatar
Pshoe
Here's a plug for Ken @KNS.
They have Giroisc rebuild kits for sale at reasonable cost.
They are pretty easy to rebuild.
Old May 2, 2025 | 02:03 PM
FRED HAMBLE
Thanks 4 the feed back. I was under the gun as the vette needed to be inspected and it failed so I was at the dealership mercy.
Thanks again
Old May 2, 2025 | 03:31 PM
Blackwater0323's Avatar
Blackwater0323
Bought a new front caliper for my 2019 GS because one of the bleeders was stripped and broke off. GM Parts Giant $530 for black colored.
Old May 3, 2025 | 12:48 PM
FRED HAMBLE
Thanks order in Yellow
Old May 4, 2025 | 01:47 PM
Photomania's Avatar
Photomania
I wonder if the dealership uses new brake calipers or remanufactured calipers. Hopefully new. I replaced the front calipers on a Ford truck and a Dodge Caravan. The replacement calipers came from Advance Auto and were remans. The Caravan’s original caliper seized up as I approached an intersection. A cloud of white smoke surrounded the tire and hood. People in other cars were honking at me and pointing at the wheel as if I did not know what was happening. Lol
Old May 4, 2025 | 05:21 PM
FRED HAMBLE
hopefully new
Old May 6, 2025 | 01:16 PM
spoolin98's Avatar
spoolin98
How the hell did your brake caliper fail inspection?
Old May 6, 2025 | 01:38 PM
FRED HAMBLE
Brake fluid leaking not from bleeder valve.
Old May 6, 2025 | 02:27 PM
spoolin98's Avatar
spoolin98
Is that why you took it in? Did the fluid ruin your wheels?
Old May 7, 2025 | 06:51 PM
FRED HAMBLE
Took it ion for state inspection an d oil change
Old May 8, 2025 | 10:15 AM
spoolin98's Avatar
spoolin98
Did you ask to see any photos of the caliper and where the leak was? The only thing that makes sense to me is that a piston seal was seeping fluid, not enough to actually drip. In this case, it's easier for them to replace the caliper but a rebuild kit is like $20.
Old May 8, 2025 | 11:34 AM
FRED HAMBLE
Yes I saw the dripping. I don't know Y they didn't offer to just rebuild the caliper. Also need to replace the pads on both front wheels
Old May 8, 2025 | 11:48 AM
spoolin98's Avatar
spoolin98
Dealerships just love to make the easiest money possible and not do what's best for the customer. They charge you for the caliper and make money off that and then make money off the labor too. Doing the seal kit, they only make a few dollars off the seal kit and a few bucks off the labor, the rest goes to paying the mechanic. Make sure you get the old caliper back, don't let someone there just swipe it and throw seals in it and sell it. Someone here will buy it and rebuild it.
Old May 9, 2025 | 03:06 PM
FRED HAMBLE
Going to see new caliper before install and my old on after.
Old May 10, 2025 | 08:49 AM
Good luck with the repair. Sucks to have an unexpected repair and be under a tight deadline for getting the work done.
To Brake Caliper
Old May 10, 2025 | 04:13 PM
FRED HAMBLE
Yes!
Old May 10, 2025 | 07:27 PM
Jdrphs's Avatar
Jdrphs
Fred
If you have non Carbon Ceramics, I have a full set of Black Brembo calipers recently pulled that only had 7000 miles on them. They are for sale. I switched to red. PM me if interested.
Old May 11, 2025 | 12:14 PM
FRED HAMBLE
Thanks 4 the offer. I had to pre pay . Waiting 4 delivery.
Fred
