Attack Blue Install
Old Jan 11, 2026 | 06:13 AM
tmbozoki@gmail.com's Avatar
tmbozoki@gmail.com
Default Attack Blue Install
Installed Attack Blue filter, took her out for test run. When I parked in the garage and turned her off, the fan in engine bay ran like crazy and it was only 44 degrees out! Did I do something wrong on the filter install? This was first time the fan ran like that (even during Texas heat) and had to restart and shut off again to stop it, WHY? Also, on down shifts, now have a little more back fire than before filter change. Have AWE Touring set up, no X-Pipe or headers.
Old Jan 11, 2026 | 09:58 AM
kodpkd's Avatar
kodpkd
Check the wire on the coolant temp sensor and the connector on the intake.
Old Jan 12, 2026 | 05:03 AM
tmbozoki@gmail.com
Any chnace youcan direct me were and which plugs these are? Sorry, still a rookie Vette owner.
Old Jan 12, 2026 | 09:47 AM
kodpkd's Avatar
kodpkd
The coolant sensor is the sensor on the water pump. You had to disconnect the wire just before the air filter to install the filter, make sure it's connected securely/correctly.
Old Jan 12, 2026 | 01:01 PM
tmbozoki@gmail.com
Got er, now got a Check Engine light, WTF
Old Jan 13, 2026 | 12:21 PM
kodpkd's Avatar
kodpkd
Can you check what the code is? Do you have an OBD2 scanner that reads codes and to clear the codes? If not, disconnect the neg terminal on the battery for 20 minutes. Be careful of the little black wire.
Old Jan 14, 2026 | 06:11 AM
tmbozoki@gmail.com
don't have a OBD reader, but gonna try thbattery cable...Does the Blue Attack cause the ECM to get confused?
Old Jan 14, 2026 | 10:24 AM
kodpkd's Avatar
kodpkd
I have the Blue Attack on my 2014. It didn't cause any issues.
Old Jan 16, 2026 | 05:35 AM
tmbozoki@gmail.com
Your battery cable idea worked! Thanks! Any idea why the filter caused a engine light?
Old Jan 16, 2026 | 09:33 AM
TKO Performance's Avatar
TKO Performance
Premium Supporting Vendor
Active Streak: 90 Days
From: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Not to worry. That C7 filter never has and never will cause any CEL. The few times we have heard someone complain, it's because they did not re install everything back properly, or something unrelated to the filter.
If you have any further issue, I suggest plugging in and reading what the problem actually is to address it.
Old Jan 19, 2026 | 06:44 AM
tmbozoki@gmail.com
Disassebled and reassembled and reinstalled filter, then did negative diconnect. Found one screw on the airlid not quite seated right, reinstalled it. All is well no more Engine Light..
Old Jan 19, 2026 | 11:15 AM
kodpkd's Avatar
kodpkd
Good job! Whew!
To Attack Blue Install
