TMPS Sensor Keeps Disconnecting
it's been I think 5 years now and not one issue ever since
I don't anticipate any new issue that can be caused by moving an antenna closer to the front passenger wheel.
If I can't fix this I am selling this car. I won't own a high performance car that can only be driven at Toyota Corolla performance limits........
Have you moved any antennas yet?
Do you know where all the antennas are? I’m seeing info saying that there is one in each door and a couple behind the dash but i can’t really verify that. I don’t mind pulling door panels but im not crazy about tearing into the dash.
1) behind the radio & climate controls
2) just behind the center console storage compartment/armrest, on the rear bulkhead wall.
3) behind the left rear wheel well liner (this is called the left door sensor in the GM service manual, but it is not in the door)
4) behind the right rear wheel well liner (this is called the right door sensor in the GM service manual, but it is not in the door)
5) rear cargo area floor, near the rear fuse/relay box, under the removal access floor panel
6) mounted on the outside of the rear tub, between the bumper cover and the outside of the tub, near the rear Corvette emblem.
The confusing portion of the service manual is because there are two different versions of the TPMS system.
There is a "UJM" system (RPO = XL7, 315MHz) for C7s exported to Japan, which does not have an auto-learning feature for wheel sensors. This system has 6 antennas.
The "UJN" system (RPO = XL8, 433MHz) used in USA C7s, has an additional antenna/receiver module "K65 Tire Pressure Indicator Module" (pn = 84429916), which is needed for the auto-learning feature. This K65 7th antenna/receiver module is mounted on the rear of the rear tub, behind the bumper cover. This module reads the signal strength of the sensor signals transmitted, and the signal strength is used to determine if a sensor is located in the front (weaker signal) or the rear (stronger signal). This info, plus the direction of rotation (CW or CCW) info transmitted by each sensor, allows the BCM to Auto-Learn determine the position of each wheel sensor (front Left, Front Right, Rear Left, Rear Right).
So, the bottom line is that the K65 module may also have something to-do with the intermittent inability of the TPMS system to read the signal transmitted from the front right passenger wheel.
Also, it is not clear to me which (or all) of the other 6 antennas are used to receive the TPMS wheel pressure signals. I suspect that only some of those 6 antennas are only used for the keyless entry and key-in-the-cabin detection and engine start authorization.
There is a "UJM" system for C7s exported to Japan, which does not have an auto-learning feature for wheel sensors. This system has 6 antennas.
The "UJN" system, used in USA C7s, has an additional antenna/receiver module "K65 Tire Pressure Indicator Module", which is needed for the auto-learning feature. This 7th antenna/receiver module is mounted on the rear of the rear tub, behind the bumper cover. This module reads the signal strength of the sensor signals transmitted, and the signal strength is used to determine if a sensor is located in the front (weaker signal) or the rear (stronger signal). This info, plus the direction of rotation (CW or CCW) info transmitted by each sensor, allows the BCM to determine the position of each wheel sensor (front Left, Front Right, Rear Left, Rear Right).
why not just do that? Take the loose wheels to a dealer and the sensors can be replaced super easy.
if you can zero in on one in particular, which it seems you have from swapping them, just take that.
I did the same thing, but mine was both fronts, and the problem was solved instantly
Plus, they say (which I haven't seen but I do think is true) that you don't actually have to dismount the tire to replace a sensor. Apparently you just use the machine that does it, but only use the tool
that presses in the sidewall off the bead, giving space to access the sensor and replace it, and then just release the tire back onto the bead. I think that's what they did with mine.
Also, any shop that does large wheels with super low profile tires can mount and dismount without harming a wheel, But still, I understand why you don't want them completely removed again.
The problem started when I replaced the original wheels. Usually tire pressure is accurately captured. But at random times communications just stop while I'm driving, and then just as randomly pick back up.
I sure hope some of you smart folks can figure this out and share a solution.
Mine was identical. One of the fronts would go out, BAM, bizarre limp mode would trigger all kinds of interventions around corners where I wasn't even CLOSE to losing control.
It made the car miserable to drive, you literally couldn't have any fun at all without driveline interference actively kicking in to alter the course of the vehicle.
If it's always the right front wheel regardless of the which wheel is in that position, I guess it could be the antenna or perhaps a connection to that antenna or an issue within the box.
Just thinking about the wheels, I assume the sensor shoots the signal through the tire during a significant portion of its visibility to the antenna.
Interesting that the passenger front seems to be source of the problem for all here?
Note that this is something Chevrolet (who made these awesome cars available in the first place thank you Mother Chevy!) would have to do, if they chose to step in.
A real fix might not be developed any time soon. But a workaround could possibly be a DIC accessible TMPS intervention opt-out. Something that changes a sensed TPMS situation to remove its input to the car's control functions. Maybe there could be a flashing light on the instrument panel to let you know that there is a sensed condition, but that would be as deep as it goes. Those folks who don't want to take this path aren't forced to take any action at all.
Of course, no lawyer in their right mind would allow this to be a hard set user selected option, this would be oe of those things that returns to the default full engagement mode every time the car is turned off.
I know the mother ship has their Corvette team busy on other things, like C9 refinement. And I understand that this is critical stuff. But I see from post #19 (I think) they do monitor what we say. So if this solution is possible, please please please Chevy, could you please see if someone can break away for a few hours to scope this out?
Assuming this temporary solution could be developed, I would gladly sit in the dealership waiting room while the technicians diddle with my Z06. Christmas is coming, be my Santa......
Also, a recent post asked if the problem was just with the passenger front. In my reading of the posts on this discussion I think the answer is no, it is not exclusively the passenger front having this problem. But yes, the majority of the comments indicate this is the most common location to glitch out.
Are you using GM sensors?
