Dot 3 brake fluid
Old May 8, 2026 | 09:43 AM
Vicorniner's Avatar
Vicorniner
Default Dot 3 brake fluid
Anyone hear about the delco dot 3 recall ? For particles in fluid? Does this mean since I just flushed my brake system I have to do it again? If so what to use? Ugh thanks
Old May 8, 2026 | 09:55 AM
Macleod52's Avatar
Macleod52
You'd need to have the old container and see what the lot number is to know whether it was the affected batch or not.
https://www.usatoday.com/story/money...l/89982556007/
Old May 8, 2026 | 10:08 AM
Vicorniner's Avatar
Vicorniner
Thanks I’ll check I bought enough at the time for 2 flushes. If so what are people using?
Old May 8, 2026 | 11:15 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Our 2017 Z51 came with DOT3 and marked on the reservoir cap. By 2019 they had switched to DOT4 and that's what the cap on those ones says.
DOT3 and 4 are compatible and can be mixed, so you can just switch to DOT4 and you should be fine. Stay away from any of the other DOT specs.
DOT4 has a higher boiling point than DOT3 but absorbs moisture from the air more quickly which reduces the boiling point after a while.
The DOT specs are minimums and there is a huge variation in actual boiling points of different brands, but I've heard it said that a typical DOT4 and DOT3 will be about equal after 2-3 years in the car.
Since I do autocross and occasional track time in our car, I just get a DOT4 flush every Spring. Also spent a few bucks and got the DOT4 cap for our car, in case someone needs to add fluid when on a road trip.
Last edited by Gearhead Jim; May 9, 2026 at 11:31 AM. Reason: Added last sentence about getting DOT4 reservoir cap.
Old May 8, 2026 | 11:19 AM
Macleod52's Avatar
Macleod52
I've just used Valvoline or Prestone. Nothing special about GM's brake fluid other than it's probably more expensive than what you can get at the auto parts store.
Old May 8, 2026 | 11:20 AM
Macleod52's Avatar
Macleod52
Oh dear god don't tell Kodpkd this.
Old May 8, 2026 | 01:22 PM
Zjoe6's Avatar
Zjoe6
https://gmauthority.com/blog/2026/05...o-brake-fluid/
If you flushed it recently, it's very doubtful your brake fluid was from 2022.
"GM is recalling 40,440 containers of ACDelco GMW DOT 3 brake and clutch fluid after federal regulators found visible sediment that could reduce braking performance.
According to documents filed with the National Highway Traffic Safety Administration (NHTSA), the affected product is ACDelco GMW DOT 3 Brake Fluid, part number 19353126, produced between October 19th, 2022 and December 28th, 2022. The recall applies specifically to bottles from lot number 01977 091222. General Motors assigned the action recall number N262552830."
Old May 8, 2026 | 05:49 PM
Vicorniner's Avatar
Vicorniner
I just checked the bottles the first numbers in the lot are the same but the second set is different so ?
Old May 8, 2026 | 05:53 PM
Macleod52's Avatar
Macleod52
If it's not a 100% match then it's a different batch.
Old May 9, 2026 | 10:03 AM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Go with DOT4
Old May 9, 2026 | 08:05 PM
rtv900's Avatar
rtv900
omg I just choked on my beer laughing at this
To Dot 3 brake fluid
