Blown engine??? Post up
Old Jul 13, 2015 | 02:52 PM
gonabite's Avatar
gonabite
Originally Posted by 3 Z06ZR1
In the past the caddy received a engine similar but not exactly the same. Be a real change if they are the same.
Yes I'm 100% sure. The only difference is the exhaust manifolds. Per a GM presentation on the car.
Old Jul 13, 2015 | 02:54 PM
gonabite's Avatar
gonabite
Originally Posted by sushisean
The heads blew on my Z07 2 weeks ago at Laguna Seca. Hopefully have the car back from the dealer this week unless some other issue comes up.
Define your "heads blew" statement please.
Old Jul 13, 2015 | 02:55 PM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
Ouch.
Was that the event where you were having cooling system issues and thought it might have been an air bubble in the system?
Sorry you had a failure.
S.
Old Jul 13, 2015 | 02:59 PM
sushisean's Avatar
sushisean
Originally Posted by Snorman
Ouch.
S.
Yep you got it. I have been laying low while I get to the bottom of it. Will post a full report as soon as I get the car back and everything is conclusive.
Old Jul 13, 2015 | 03:04 PM
Snorman's Avatar
Snorman
Thanks.
S.
Snorman's Avatar
Snorman
https://www.corvetteforum.com/forums...h-6-miles.html
Here is the thread about the car with 6 miles that had a failure.
S.
Old Jul 13, 2015 | 04:03 PM
sushisean's Avatar
sushisean
The car requires new heads to be installed because the old ones warped.
Old Jul 13, 2015 | 04:17 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Well if it is 10 engines of 10,000 pretty low. .001 percent! Sounds like no worry unless of course you have unlucky and landed in the .001
Um, 10/10,000 is .001, which is .1%.
Doug
Old Jul 13, 2015 | 04:21 PM
docb's Avatar
docb
Well if it is 10 engines of 10,000 pretty low. .001 percent! Sounds like no worry unless of course you have unlucky and landed in the .001 and some of those 10 we don't
know but a few could have abused the car too much too early.
We know cars with 37 miles on the odo have been to the strip with all out passes at 37 miles. That one didn't fail yet.
These cars have coatings on the bearing's that needs a proper breakin for best results. The 500 mile break in oil is fine. Is not a issue.
There is no issue that I see so far. I do think the 1lt has oilling issues
the lt4 is better in my book
Numbers are still very small, but actually it's .1%
Old Jul 13, 2015 | 04:48 PM
Snorman's Avatar
Snorman
Interesting data about engine failure rates:
http://www.autoexpress.co.uk/car-new...#ixzz2IhIaAMyJ
http://www.warrantydirect.co.uk/press269.html
It's a few years old, but interesting data.
So take the rumor of 13 failed Z06 LT4's. Then multiply it by 5. It represents a ~.85% failure rate, or about 1 out of 119 cars. About the same as Mercedes-Benz, or #3 on that list. And it's a 650 hp high performance supercharged engine.
That should put in perspective how overblown and exaggerated the claims that the LT4 is a failure are. That being said I'm sorry for those who have had issues and think a list to document failures is a pretty solid idea.
S.
Old Jul 13, 2015 | 07:27 PM
2003Evo's Avatar
2003Evo
It seems like everyone is screwing up now days..even Gen V's seem to suffer from this illness
http://www.viperalley.com/forum/vipe...c-failure.html
Old Jul 13, 2015 | 07:50 PM
69L79's Avatar
69L79
From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
Question: How many Z06 owners don't post to this Forum? If that was known the failure rate would be more accurate. Possible failures may never be reported to this Forum. GM sure as Hell wouldn't release any numbers.
Old Jul 13, 2015 | 08:07 PM
  #33
RBK11's Avatar
RBK11
Maybe this thread should identify the "individual(s)" who built the blown motors. Who knows, we could have a "saboteur" in our midst (probably really works for Dodge). Best
Originally Posted by docf
The question regarding who built the blown engines has not been answered. Of the supposed 13, so far I see 2 on this post, both built by an individual. The most recent blown which was driven by the press also appear to have been a Z07 thus again built by an individual. I too would opt for an automated build, not only for engines, but paint etc.
Old Jul 14, 2015 | 12:05 PM
  #34
ZeeOh6Nut's Avatar
ZeeOh6Nut
There is little difference between the production methods for the hand built engines and the production ones other than where they are built and a few assembly details. In most cases they use identical tooling. If the so called production assemblies make any increased use of automation that would tend to make them a little less likely to have build issues. Robots don't make mistakes like humans do.
Bill
on automation enhancing quality and how there is probably little difference in the build methods.
I toured the Wixom plant in 2006 and saw some hand-built LS7's. Everything was recorded on a build down to the torque for every bolt. All data acquired is automated from the tools used which are all connected to their network. A book (thick) accompanies the packaged engine when completed. I left with a strong impression that any failures would be from parts that had imperfections such as the valve train issues on a few C6 Z06's.
My point being that whether hand-built or robotic, it's all automated and tracked beyond what I ever imagined.
Parts fail and warranties cover them. Sorry to hear about the engines that have failed and I hope everyone who has experienced this gets back to the fun asap. I haven't had an engine failure yet but the issues I've had on the GM vehicles I've had, including 4 Vettes purchased new, have been taken care of. Once I had to wait a month for the completion of the warranty work on my C6 Z06 but so far GM has never left me to twist in the wind.
Old Jul 15, 2015 | 03:04 AM
  #35
walhan_qtr's Avatar
walhan_qtr
Mine blew. 283miles. 2015 Z07 built by Jeff Beckman
Old Jul 15, 2015 | 10:49 AM
  #36
Busa Dave's Avatar
Busa Dave
After seeing the failed engines that were built "by hand" I am not really surprised. Mine was built by some chic in BG---hope she was having a good day and it was not built on a Friday! A marketing gimmick that I do not buy into--may fool some of the older drivers who feel that they are getting a better engine by gum! That may have been the case in 1979 but not now.
In my world aerospace "by hand" means problems... Seen it for too many years.
Old Jul 15, 2015 | 02:03 PM
  #37
CPhelps's Avatar
CPhelps
In the past when GM has done this, the engines got different RPO codes. IE the LSA in the CTS-V and Camaro ZL1 vs. the LS9 in the ZR1. This time GM is saying LT4 by RPO code will be in the CTS-V.
To Blown engine??? Post up
Old Jul 15, 2015 | 02:10 PM
  #38
NORCAL-SS's Avatar
0NORCAL-SS
Former Vendor
List updated if you see or hear more link me
Old Jul 16, 2015 | 04:09 PM
  #39
Shysterman69's Avatar
Shysterman69
It happens to all automakers, it is a mechanical engine... Here is a nice little nugget from Porsche for example... Yeah this is happening...
http://blog.caranddriver.com/some-po...engines-again/
Notice it says "Again".
Does not sway my opinion of my Z06 at all. Fantastic car!
Old Jul 16, 2015 | 04:47 PM
  #40
C7_Z06's Avatar
C7_Z06
I agree the Z06 is still a great car. However in fairness, the good thing is Porsche owns up and proactively volunteers to promptly resolve the issue. Others <ahem ahem GM> either do less to remediate or take a long time just to initiate and follow-through with a corrective action.
