Sponsored by: GEM Motorsports
CPR's single turbo kit is done!!
Old 01-01-2017, 11:07 PM
EkS
EkS's Avatar
I know you said you have many options on the kit, but what's the entry level price for the kit?
Old 01-02-2017, 10:34 AM
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,237 Likes on 779 Posts
It would be better to email me letting me know what kind of power you're after, if you want a boost controller or not, etc. That would allow me to quote it out based on your goals.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old 01-03-2017, 05:58 AM
johnglenntwo
johnglenntwo's Avatar
Default Intercooling?
Originally Posted by Joe@CPR
There it is! The first turbo C7z (that we are aware of) is ready for tuning. This vehicle came in all stock and we developed our single turbo kit for the Z & stingray platform. Turbo on this car is a precision 8847h, feeds to the oem exhaust and retains 100% oem components in terms of ac, cooling capacity, etc. We also developed our high hp fuel system on this car to be an option over our already popular standard low side system. Power goals for this vehicle are in the 1100+ rwhp range or wherever this turbo maxes out. Kit will be available with smaller turbo options and will only be installed in house at our facility. Pricing has not been determined yet as we have a lot of items to still go over in terms of components into the kit. Absolutely zero corners were cut for this truly first class system.
Key features over other systems.
-zero ground clearance is lost
-no cutting of the body at all
-no relocating the fuse block
-easier than stock to service spark plugs on down the road
-zero china parts, this is made using the top tier quality stainless available, schedule 40 on the manifold, etc.
-retains oem air box for a clean look, for max power at the track simply pull the coupler or put a filter on the inlet of the turbo. We have tested the oem air box on blower cars to over 1000 rwhp so it's not a huge restriction
-PTP turbo blanket, something many others overlook is using the absolute highest quality blanket available. you can put your hand on it during a pull!
first pic shows the complete kit, second pic showcases the hard line coolant pipes we made for this. We truly wanted this to be a first class kit that will make you proud to showcase, and give you years of trouble free performance.
Front of radiator equals heating up! (STS)
Old 01-03-2017, 07:08 AM
Supporting Vendor
Don't compare this quality USA made system and components to a junk sts kit. There is no overheating, or any issues running this system the way we made it. It's like countless kits before it on other platforms.
Old 01-10-2017, 01:44 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Aww, come on Joe. Turbos for mufflers, intake tubes for days that look like subframe connectors, and exposed air filters behind the rear tires...what's not to like?
Old 01-10-2017, 03:17 PM
Earl H
Earl H's Avatar
When will the kit be available for non CPR installs?
Old 01-10-2017, 03:37 PM
Supporting Vendor
unsure, and might not ever offer it outside of the shop. I am super **** about quality control especially on this, and not sure I want to deal with people asking for all the tech support of self installing.
Old 01-10-2017, 03:47 PM
Earl H
Earl H's Avatar
Open to working with shops...say Mi.?
Old 01-10-2017, 03:50 PM
Earl H
Earl H's Avatar
Just called and recd my answer...unfortunate.
Old 01-10-2017, 04:38 PM
kutlow
kutlow's Avatar
I dont like the look of this kit. Too much going on with the Intake tube. Too hard to make the engine bay look good. Why not just put it at the rear?
HIGHPSI707 (03-05-2017)
Old 01-10-2017, 05:56 PM
Supporting Vendor
[QUOTE=kutlow;1593837803]I dont like the look of this kit. Too much going on with the Intake tube. Too hard to make the engine bay look good. Why not just put it at the rear?[/QUOTE
That's fine you don't like it, different strokes for different folks
Old 01-10-2017, 06:21 PM
Ben@WeaponX
Ben@WeaponX's Avatar
St. Jude Donor '14
Well done holmes
Old 01-10-2017, 06:39 PM
  #33
VictorBarron
VictorBarron's Avatar
[QUOTE=Joe@CPR;1593838412]
I think the engine bay is killer.
Old 01-31-2017, 04:47 PM
  #34
CFHay
CFHay's Avatar
Kinda shitty they titled the video with the shop you built the car for.
Quick Reply: CPR's single turbo kit is done!!
