Just got my 17 Z06. I have read on the forum that alignments from factory are hit or miss. Also read that GM will provide a free alignment. If the free alignment is true, how does one go about getting this? Does the car have to exhibit alignment problems, like abnormal tire wire, before GM will do this alignment? I don't want to wait until the tires show abnormal wear to get the problem corrected. May have to take the car to a reputable alignment shop and pay for alignment.
Another question. I have read that there are two alignment specs, one for street use and one for track use. Which spec does the factory use?
My Factory alignment was within specs. The Z is shipped with street alignment.
It's hit or miss. There's a street/track alignment that DSC recommends that works great. My initial alignment was way off and I ended up replacing the front tires before 10,000 miles. I'd suggest getting it checked. I wish I had earlier.
Bring it to the dealer and say it pulls hard to the left. They will check it and align it to street spec if out. This is what I did, mine was mildly out and they aligned to street spec.
Take it to an alignment shop you trust and get the DSC ‘Street’ alignment. Remember one thing: rear caster is crucial to handling stability, and most dealerships won’t have the requisite adapter block and digital angle gauge needed to set it. Hell, some still don’t know that rear caster can be set on the C7. It’s as important as any other alignment setting btw.
Bish
That may not work since they probably don't have any more idea about setting rear caster than any other regular automotive shop or most performance shops. It takes some serious questioning and deciphering of the people's answers to understand if they know what they are talking about.
Bill
I agree. It's hard to find anybody that has a clue about the rear caster. I ended up buying the tools and doing my own alignments because it was less trouble than taking it to someone that knew how to do it. For me it was over an hour drive in each direction plus the time to do the alignment. It's simpler to do it myself.
What equipment/tools do you have to do your own alignments and level of difficulty?
There's a thread on here that Poor-sha, I think, started. I got the factory tool and guage for the rear caster. I got the tenhulzen setup for the alignment.
I put the AMT camber plates and Granatelli toe bars on and the settings Poor-sha used on his car put me really close to start with.
As long as you have a level floor and are patient it's not too hard to do. It is time consuming because you'll need to drive a few miles between settings to make sure your adjustments are correct.
Equipment and tools can be pretty simple. To get a decent alignment you can start with a Sears 24 Inch Digital Laser Level. That will give you camber, front wheel caster and thrust angle, you will also need a couple of tape measures that are marked in 1/32 increments (1/64 is too hard to read), a set of toe plates and a person to help with distant measurements.
To set rear caster you will need the GM Rear Caster Adapter tool which runs about $200 shipped from Bosch. You can get by with a Wixey saw blade angle gauge that has 0.1 degrees of accuracy. You have to make sure you order the correct Wixey because most of them have 0.2 degrees of accuracy which is too much when you are trying to make degree measurements that vary between +0.8 degrees and -0.8 degrees and want them to be as close as possible to being equal from one side of the car to the other. A +/- 0.2 degree reading isn't much better than guessing. With the 0.1 gauge you can be pretty sure if you have a 0.7 degree reading on each side that they can only be a maximum of 0.2 degrees apart.
Any other tools that you add just make the job easier.
Bill
I was not talking about taking the car down to your local Sears, Bill. Obviously the Z06 owner needs to call around to find a ‘race type’ shop that knows exactly what they’re doing regarding alignments. I have a local shop run by two ex-SCCA racers. They have top of the line equipment and a sophisticated digital angle gauge. I took them my rear caster adapter, and since it was aluminium they made their own from steel using their CAD/CAM machine. The alignment they gave me and the stability on a road course, plus when punching the accelerator from a stand still was amazing. Anyone who doesn’t take the time to find a shop like this is missing out, and I can guarantee the alignment from professionals is far more likely to be correct versus someone trying to do it for the first time in their garage.
Bish
I agree if you can find that shop. The problem is that sometimes they don't do it right either. I took my car to a shop in Cary that was supposed to be the best around. The do all the tech for the scca in this area and they managed to mangle one of my AMT plates and screwed up the rear alignment so bad the car felt dangerous. That's when I decided to buy the equipment and do it myself.
My alignment was off from the factory but you you could not really tell with normal street driving. Woke up one morning with a low pressure light and low and behold the fronts had worn down to the cords and I assume was causing a slow leak. GM would not pay for alignment or new tires. Only 14K on the car. I was told that they only adjust within the first 7500 miles.
Bish
The fact there are a bunch of us Turkey's on the forum that can do the alignment ourselves indicates it isn't impossible to find a shop that can do the work. The problem is most performance shops, race shops, dealer shops, Sears Repair Centers and Joe Blow's Garage haven't heard of adjustable rear caster. They usually have done so many alignments they just blow off anybody that mentions rear caster as being a member of Poly Public that has no idea about anything. The same kind of treatment that most women get from them all the time.
You were lucky you found somebody that listened. Most don't because it requires a paradigm change on their part.
Bill
It's not just that. First of all, most shops aren't going to want to put the time in it takes to really get an alignment right. If they are charging you a flat $99 or something they are going to bang it close enough and call it a day.
The other issue is that alignment racks get out of calibration and most shops never bother to check and adjust them. I watched DSC check their rank before they ever put my car on it.
What exactly are the DSC Street Specs so I can hand them exactly what I want?
Also how many miles, minimum, do you need on the car before making this investment? I would guess 500 to 1,000 miles.
Years ago I took my Z to a shop that also balanced the wheels on the car. It was interesting to watch. They also put nitrogen in the tires. The Z rode and handled so well after that, and it was not bad to begin with. I really felt the on the car balancing of the wheels was a big improvement vs. Taking them off and doing it on a machine.
Also how many miles, minimum, do you need on the car before making this investment? I would guess 500 to 1,000 miles.z
