Sponsored by: GEM Motorsports
Toyo R888R on stock Z06 wheels
Old 12-03-2019, 08:08 PM
  #161
Toddiesel
Toddiesel's Avatar
Originally Posted by gshirst1
Thanks Toddiesel. Foreverfuelie, these won't be available to the public for likely 60 - 90 days. Toddiesel, do you have the occasional rear rub in Tour or Sport mode?
It really never rubs, even when i'm pulling .9+ Gs on an on/off ramp or something like that. I have to hit a serious dip in the road when I bounce in my seat
Old 12-03-2019, 08:12 PM
  #162
gshirst1
gshirst1's Avatar
Got it, thanks.
Old 12-16-2019, 02:23 PM
  #163
stone150
stone150's Avatar
Has anyone tried 305/30/R19 for the fronts? Looking to get more grip in the front.
Once of the guys this weekend was running 315/30/R18 and 335/30/R18 on his Vette for road course use.
Old 12-16-2019, 02:50 PM
  #164
MCK_Z06
Support Corvetteforum!
MCK_Z06's Avatar
A wide 18" wheel tire will almost always be better on a track with corners.
I have a 295/30/19 up front and this a decent compromise street/track size that wont mess with the factory stability/traction control calibrations.
That's on an OEM size front wheel (19x10) a 19x10.5 or 19x11 wheel would probably improve grip a little more but may rub a little depending on ride height, spring rate, etc. etc.
A 305 is too much for a stock 19x10 wheel and would probably reduce front grip (in my opinion)…. now on a 19x.11 inch wheel.....it would probably help.
Old 12-16-2019, 03:06 PM
  #165
Toddiesel
Toddiesel's Avatar
I ran 305s on a 10" wheel on my 2013 Mustang GT and had no issues. I'm not sure how much difference it makes being up front, but I had even tread wear and all that. Same profile, though an inch bigger wheel. 305/30/20
Old 02-01-2020, 08:18 PM
  #166
gshirst1
gshirst1's Avatar
Have pulled the trigger on new rubber and wheels. Am going with the R888Rs all the way around. 345/30/19 on back and 295/30/19 up front. New wheels are Cray Astoria gloss black with mirror cut face. 19/12 in back and 19/10 up front. I have an Arctic white 2016 Z06 and am hoping the mirror cut on the wheels provides a complementary color to the body color. Will post pics when installed. Will keep the OEM wheels and MPSS tires for long road trips.
ernhart333 (02-01-2020)
Old 02-01-2020, 08:24 PM
  #167
ernhart333
ernhart333's Avatar
Can't wait to see your set up!!
Old 02-01-2020, 08:30 PM
  #168
gshirst1
gshirst1's Avatar
Grip should be off the charts. Not that the MPSS's had bad grip, but these Toyo's will have a grip like the Incredible Hulk!
Old 02-01-2020, 08:41 PM
  #169
ernhart333
ernhart333's Avatar
I hope so, I will be getting my Toyos soon and Walmart seems to have the best price I have found so far.
Where are you buying yours?
Oh here are my rims and my car is at Katech getting the stage 3
These are the 19/20 Forgeline EX1's from Gerry at CW4L
Weights OEM vs Forgelines (Forgelines on the left OEM on the right)
Note the Forgelines with the OEM caps I machined to fit the Forgelines.
Fronts: OEM = 28lbs Forgelines = 24lbs
Rears: OEM = 33lbs Forgelines = 25lbs (this seems like a huge savings)
Old 02-01-2020, 08:59 PM
  #170
gshirst1
gshirst1's Avatar
Wow! What a spectacular ride. Those wheels will look killer on the Z car. Significant weight differential between OEM and Forgelines. Are you going 325/30/20 on the back?
Old 02-01-2020, 09:02 PM
  #171
gshirst1
gshirst1's Avatar
Note the Forgelines with the OEM caps I machined to fit the Foreglines.
Oh, and BTW I am getting everything thru TireLink. What price does WM have for the Toyos and what sizes are you getting?
Old 02-01-2020, 09:13 PM
  #172
ernhart333
ernhart333's Avatar
Yes sir I'm going with the 325/30R20's rear and 295/30R19's on the front.
Here at the Walmart in Pa I got a price of $475.90 each rears and $335.73 for the fronts
Are these close to your prices?
Old 02-01-2020, 09:34 PM
  #173
Toddiesel
Toddiesel's Avatar
you're telling me WALMART carries Toyo R888Rs??? No way!
Old 02-01-2020, 09:36 PM
  #174
gshirst1
gshirst1's Avatar
Yes, price I was quoted is $500 for the rears (345/30/19) and $345 for the fronts (295/30/19)
Old 02-01-2020, 09:41 PM
  #175
ernhart333
ernhart333's Avatar
Yeah and they said they will price match but so far I have not found them cheaper any where!!
Old 02-01-2020, 09:55 PM
  #176
ernhart333
ernhart333's Avatar
Old 02-01-2020, 10:01 PM
  #177
gshirst1
gshirst1's Avatar
Looks good. I did not know WM carried Toyo's
To Toyo R888R on stock Z06 wheels
Old 02-01-2020, 10:19 PM
  #178
Toddiesel
Toddiesel's Avatar
RIGHT?? That seems crazy to me. The dichotomy of high end, practically track tires at a trailer trash place like walmart... *mind blown*
Old 02-01-2020, 10:22 PM
  #179
ernhart333
ernhart333's Avatar
And with some of the best pricing around to boot!
LOL
Old 02-01-2020, 10:27 PM
  #180
SpeedyVette
SpeedyVette's Avatar
Warning Warning Will Robinson! Reconsider having Walmart install these. on your rims! Don't say you were not warned !
Quick Reply: Toyo R888R on stock Z06 wheels
