C8 General Discussion The place to discuss the next generation of Corvette.
Sponsored by: Wheel Design
Leaked performance data!
Old Aug 26, 2019 | 11:57 AM
  #41
keagan's Avatar
keagan
Originally Posted by fasttoys
If the Z06 is a manual it will be a tough race to 100 MPH after that I am not sure. DCT will give C8 advantage coming out of the gates.
Assuming a good driver in both cars, the Z ain't got nothing to worry about, whether its M7 or A8. Just my lousy 2 cents.
Old Aug 26, 2019 | 11:58 AM
  #42
G fix needy's Avatar
G fix needy
Originally Posted by Mike Campbell
I would predict that these C8's will show up at the tracks and drag strips all around the country and they'll live up to those figures. Just saying!
I agree. The DCT + launch control should remove the driver variable (apart from his/her weight) in 0-60 or 1/4 mile times.
Old Aug 26, 2019 | 11:59 AM
  #43
Fore58's Avatar
Fore58
According to the data, both cars are right there by the time they cross the 1/4 mile. There are no other indications. No difference between the C7 Z51 and base model it appears. The Z51 should have a slight edge for what it's worth. So both cars are at 11.3@121. That's very quick. Now once the boys get a hold of this car on a well prepped track, possibly lower 11's or high 10's
Old Aug 26, 2019 | 12:04 PM
  #44
thill444's Avatar
thill444
The numbers are solid. But we have somewhat known this since the reveal, with the DCT and more technology than ever in a mid engine car that can put the power down better this car is going to be a crazy amount of performance for the price.
I can't even imagine what the C8 Z06 and Grandsport will be able to pull off.
Old Aug 26, 2019 | 12:05 PM
  #45
NW-99SS's Avatar
NW-99SS
2022 C2 of the Year Finalist - Modified
I find those times very interesting and the comments that GM is overly zealous with their performance numbers is simply not true. I recall the times stated for the C5, the C5 ZO6, the C6, the C6 with the LS3, the C6 ZO6 and ZR1 and later the C7 base, Z51, ZO6 all were conservative at the time and many drivers exceeded those numbers with regularity. As to the car mags never making those times you have to realize 2 things. They test those cars over a relatively short period of time and really never get to know exactly how to get the best times and they do an average for their publications. It's all about "seat time" and anyone owning a car knows what I'm talking about. Just go on the "Fast List" for any of these cars and check out the "Stock" times. Finally so many of the car mags also tested M7's which like it or not are slower than the autos. I would predict that these C8's will show up at the tracks and drag strips all around the country and they'll live up to those figures. Just saying!
This, plus all the mag times are on un-prepped surfaces. The fast list times come from guys who take their cars to the track where prep helps traction and improves on GM's performance claims. I believe GM uses "street" scenario traction to produce their publication performance stats.
  #46
gthal's Avatar
gthal
Not sure I agree... if A8, yes. If MT, then even with a good driver it will be tough for the Z06. Look at the R&T tested times for the Z06... 11.5s in the 1/4. The DCT in the C8 will be easily repeatable and the GM result likely easily replicated by normal people. How many MT Z06's are we seeing consistently hit 11s flat in the 14 mile? Not many.
Even with absolutely perfect shifts, the Z06 has more traction concerns, there is a let off of the throttle, etc. I bet to 100mph, a C8 will get the jump on a MT Z06 even with a great driver. Now, that jump won't last all that long because by the 1/4 mile, the Z06 is trapping a higher speed and pulling away. R&T tested a MT Z06 at 7.6s to 100mph. Exactly the same as GM's number for the C8.
Traction, DCT, gearing all play an important role in acceleration to 100mph... after that, the C8 doesn't stand a chance being down 150HP.
Old Aug 26, 2019 | 12:08 PM
  #47
Tarl's Avatar
Tarl
Looking good! Exciting times ahead!
Old Aug 26, 2019 | 12:10 PM
  #48
Metraman's Avatar
Metraman
Z51 for resale when the ZO6 comes out.
Old Aug 26, 2019 | 12:48 PM
  #49
lostsoul's Avatar
lostsoul
Banned Scam/Spammer
If it does or doesn't beat a Z06 it will be close enough which helps those on the fence thinking for the same price for a c8 I can get a Z06. Even though I have given them some sh't about options and NPP being spinless, they have been able to pull off a nice upgrade.
Old Aug 26, 2019 | 01:13 PM
  #50
faldoc's Avatar
faldoc
These numbers make the Z51 package less attractive for all practical purposes. For my driving it would be wasted. Thanks for the info.
Old Aug 26, 2019 | 01:18 PM
  #51
Dads1le's Avatar
Dads1le
Default Weak braking and lateral G specs?
Anyone else notice these specs Would have thought braking would be closer to 100 ft or less and lateral g to be over 1 g. Probably reading too much into unofficial specs but has me wondering if the non Z models will be more of luxury touring piece than a sharp handling instrument?
Old Aug 26, 2019 | 01:22 PM
  #52
MitchAlsup's Avatar
MitchAlsup
Originally Posted by ChevyChad
Awesome! So 0-60 for the non-Z51 is 3.0 (only .1 quicker than the Z51). Bad ***!
Given that we knew (last week) that Z51 car has 0-60 of 2.95 and
that the Z51 has 6% more thrust (differential ratio ratio) AND
that the Z51 car takes 2 shifts to 60 MPH while the non Z51 takes only 1
We could postulate that non Z51 should take 2.95*1.06 = 3.12 - 0.1 = 3.02 seconds 0-60
(the -0.1 is the missing shift)
This lines up nicely with the newly presented data.
However, the non Z51 will be slower (by that 0.1) to 65 MPH due to the additional shift.
Old Aug 26, 2019 | 01:53 PM
  #53
punky's Avatar
punky
Banned Scam/Spammer
Good math, interesting , understand that these are imperceptible differences and very, very, few of us will ever reproduce these numbers in the real world.
Old Aug 26, 2019 | 01:59 PM
  #54
rcooper's Avatar
rcooper
St. Jude Donor '15
Originally Posted by Iker
The old school engine still consume a lot of fuel so that’s why they are using long gears to improve fuel economy!
What I hate about C7 that’s you will be killed in street races by cars 100 hp less than you once you are in super long 5th gear I really hate it
I think the same story will happen to the C8
0-60 time is nothing
Really, street races...
Old Aug 26, 2019 | 02:05 PM
  #55
vndkshn's Avatar
vndkshn
I'm actually kinda surprised that GM didn't do the math a little better and have even the Z51 car require only one shift (fine, banging the limiter at 60). Given the math works out to 59mph in 2nd, I think that is exactly what they were shooting for and just missed it somehow.
Old Aug 26, 2019 | 02:07 PM
  #56
50MileSmile's Avatar
50MileSmile
Bragging rights are different than the reality: 90% of you guys will never find the tenth between the base and the Z51 (or the C7 Z06) - or even bother to go looking for it. Screen racing (today’s version of bench racing) is always fun, but the reality is the C8 is a remarkable achievement and the fast guys will soon learn its tricks - and the C7 Z06 being faster discussion will never come up again.
Old Aug 26, 2019 | 02:08 PM
  #57
Kappa's Avatar
Kappa
Originally Posted by punky
You mean the guys who called some of us "morons" for predicting a 0.1 of a second difference with such a minute difference in gear ratio?
Nope. The guys saying this was going to be a high 11's car and would barely be quicker than the C7 Z51 let alone challenge a C7 Z06 to 100mph from a standing standing start.
To Leaked performance data!
Old Aug 26, 2019 | 02:09 PM
  #58
Harbgrogan's Avatar
Harbgrogan
My LS3 trapped 122-123 stock, I wonder what the c8 traps in the 1/8th mile though.
Old Aug 26, 2019 | 02:25 PM
  #59
gthal's Avatar
gthal
I’m reading nothing into that. Everything GM has said is that we will all be very happy with the measured performance and that they benchmarked off some very fast cars.
If that turned out to not be true, the car would be a flop and GM isn’t going to let that happen. If the C8 was a poor performer and GM said “just wait for the Z06” they would lose way too much momentum with this car. They aren’t that stupid.
This car will perform exceptionally well and represent the Corvette badge very well.
Old Aug 26, 2019 | 02:28 PM
  #60
_M_'s Avatar
_M_
And we are sure this is legit? and not just some random made up internet thing ?
