Front tire max width
Thank you!
Specs in the link:
https://www.corvetteforum.com/forums...t-options.html
Provided a list below from the Net that fits my experience on what can be done to "reduce" Oversteer. As noted, to reduce Oversteer you could install narrower front tires. Below I'll cover what I did and what Tadge said about why his biggest fear with the C8 design was would they be able to eliminate Oversteer! He, Andy Pilgrim (former Corvette Team racer,) and others say they achieved their objective!
SIDEBAR (Only for those who can deal with more than 280 character communications!)
There are many factors determining oversteer and understeer. To counter the inherent Corvair Oversteer GM specified 16 psi pressure in the front tires for all years. Few owners, gas stations (who back-in-the-day checked -and adjusted if needed- tire pressure while they pumped gas) and even Chevy dealer techs followed that requirement and often used the typical 30 psi on all 4. That caused some of the driver issues even on the '65 and later Corvairs!
First thing I did with the '67 was dump the Uniroyal "Tiger Paws!" I joked that GM must have put those on to give an early warning to the average Corvair owners who had no idea how to deal with a 60% rear heavy car! They "growled" as you made a turn at ~60% of the max lateral "g" force. Went through several tire brands including Pirelli Cinturato 72s (if I recall the name correctly.) Those skinny 13 inch tires were some of the first radials. Great in the ran, my objective in buying, but not best for dry handling. Then found Continental 714 high performance radial tires at the NY Auto Show and their published info and Show rep said "had to have those." They were low profile when that wasn't a "word used." But they only came in 14 inch minimum size so had to go to Plus 1 (another "word" not used at the time!) Took lots of measurements and found custom wheels for a Chevelle that had the right offset! Great tire in wet and dry.
To provide additional help with Oversteer GM used an unusual rear rear toe-in spec, 1/4 to 3/8 inches! I set it up with the max 3/8 inch toe-in! A cheap form of rear steer! In a high "g" turn the highly loaded outside rear wheel was trying to steer back into the center of the turn! My '67 had every HD option offered that year including quick steering, HD springs, sway bar and metallic brakes. I added headers, carb mods and finned (+ internal pins) aluminum oil pan and valve covers to help control oil temp (which helped but it still got very hot!)
Great handling car. But at the limit, when going to fast for a turn, you had a split second to steer like a dirt track driver to avoid spinning off the road, rear first! If you turned the wheel as if in a skidding FE car, even for a split second, you'd be off the road very fast, rear first! When testing the maximum turn speed at the limit, needed to counter steer. It was actually fun and you could anticipate when it would be needed! Porsche's of that era had the same issue! In fact Tadge said his dad was a military pilot and drove his Porsche at the limit! Tadge said he knew "all about oversteer" in a rear heavy car. In the ~I hour Autoline interview video he said "Oversteer Was His Biggest Fear with the C8 Design! In another written interview he said "It took Porsche decades to correct the issue and they (GM) had to get it right the first time!" He only gives a few clues of what they did or what Porsche gradually found over that long time to make a ~63% rear weight car into a great handler! He did give a clue in that Autoline Interview.
BOTTOM LINE
GM spent a lot of time and engineering effort with the C8 to achieve a slight amount of Understeer so the average Corvette driver, if going too fast for a turn, can manage to deal with a skid. They give few clues as to what they have done. However tire size (brand/model) would be a key variable, as is tire pressure, sway bar and spring selection, etc. I'd be very careful changing what they designed without some knowledgeable input. Just like for Tracking alignment GM defined can be used.
Ways to Correct Oversteer (from Internet source that fits my ~10 years experience with Corvairs)
- Lower front tire pressure
- Raise rear tire pressure
- Stiffen front shocks
- Soften rear shocks
- Raise front end
- Lower rear end
- Install narrower front tires
- Install wider rear tires
- Stiffen front sway bar
- Soften rear sway bar
- Reduce front negative camber
- Reduce positive caster
- Stiffen front springs
- Soften rear springs
This is leaked info from the GM Hybrid. Data is from the article posted on the following Thread on C8 Tech/Performance in November 2019 for the wider C8:
https://www.corvetteforum.com/forums...-drive-c8.html
Shows the tire sizes GM says will be on the "wider" ASD Grand Sport or Z06 Hybrid (the article doesn't say which BUT since the ICE mentioned is the standard LT2, my thought is it's the Grand Sport.) Note top Pic is one I picked up from an other magazine "guess," just the data is from the leaked article! Body width is my estimate based on the tire size the article quoted and my Grand Sport over base C7. Bottom Pic IS from the leaked article!
(And BTW, anybody who experiences "understeer" in this car on the street is likely to either end up in a tree, or in jail)
That said, a wider tire in the front may cause a lot of unintended consequences.... scrub, tram-lining.... every tire brings a different set of construction and driving characteristics, and engineers do a lot of testing to match the specific tire to the suspension tuning and alignment.
Maybe it will work, maybe it won't but without serious testing, you may be doing more harm than good... who knows
Thank you!
I have been running in SS / AS (C7) and now BS in my current 2020 M2Competition. The RE71R rules for the stock classes IMHO.
Thank you all for your feedback and input! Most appreciated.
OEM 305/30/20 Michelin Pilot Sport 4S are (based on 11" rims) = 12.3" Section Width; 11.2" Tread Width; 26.4" diameter;
325/25/20 Michelin Pilot Sport 4S are (based on 12" rims) = 13.2" Section Width; 13.2" Tread Width 27.2" diameter;
(Note the use of a wider rim for the measurements won't affect Tread Width with but will reduce Section Width perhaps 3/8 to 1/2 inch less.
The speedometer will be off 27.2/26/4 + 3%, i.e. it will read 3% lower speed so speedometer at 60 mph you'd be going 62 mph. Looking at the room around the rear tire it should fit, helped by being only ~1/2 inch Section Width difference.
This is for the front:
OEM 245/35/19 Michelin Pilot Sport 4S are (based on a 8.5 rim) = 9.8" Section Width; 8.6" Tread Width; 25.8" diameter;
265/30/19 Michelin Pilot Sport 4S are (based on 9.5 rims) = 10.7" Section With; 9.6" Tread Width; 25.3" diameter;
(Note the wider rim won't affect Tread Width but will reduce Section Width perhaps a 3/8 to 1/2 inch Section Width difference.
The speedometer will be off 25.3/25.8 = -2%, i.e. it will read 2% higher speed so speedometer at 60 mph you'd be going 59 mph. Have to check room full lock right to full lock left. In this case the Section Width will be similar, i.e. 10.7" with a 9.5" rim should Redcue to ~10.3" on a 8.5" rim or only ~1/2" larger.
I played around and got it to about 1.9%, and it SEEMS to work OK, but this is the kind of stuff you need to consider...these cars are so computerized, and there is not a lot of really hard info out there.
FWIW, when the tire wears it could be 2.3% difference in diameter = difference in circumference!
C8 Front tire diameter = 25.8 inches. OEM C8 Tread depth = 9.5/32 = 0.297" X 2 = 0.592/25.8" = 2.3%!
GM surely covered that.
