Sponsored by: Wheel Design
Oil catch can
Old Sep 11, 2020 | 10:16 PM
gbf_98070's Avatar
gbf_98070
Default Oil catch can
Horsepower Obsessed recently put up a video where he showed the installation of an oil catch can on his C8. It’s a nice piece of kit and looks to be an easy project but I’m confused about one thing. Doesn’t the C8 already have an air/oil separator? If so, why would I need a catch can in addition? Would it really make that much difference?
Does anyone have a link to a searchable parts catalog that includes engine and accessories? How could I research this?
Thanks for any help!
Popular Reply
Sep 11, 2020, 10:34 PM
Zymurgy's Avatar
Zymurgy
Moderator
Let's see. GM has a 5 year 60,000 mile powertrain warranty on the C8. If they felt it needed a catch can, it would come with it. The debate will rage on.
Old Sep 11, 2020 | 10:34 PM
Zymurgy's Avatar
Zymurgy
Moderator
Old Sep 11, 2020 | 11:58 PM
Tracy's Avatar
Tracy
The catch can is good for 28 horsepower. Fender hash stripes make almost 15. Together, we're talking real power gains. Adding crappy Chinese LEDs to your engine compartment increases all of those gains by 1.6%.
Do it!
Old Sep 12, 2020 | 01:13 AM
AzDave47's Avatar
AzDave47
A catch can would take the oil fouled air from the valley cover that now goes to the intake manifold and get burned, and separate out the oil so that you still get crank case ventilation but do not fill the intake manifold and intake valves with oil residue. In normal driving very little oil flows thru that system. On a road course in a C6Z, running 4-7K RPM and then hard throttle close under braking will generate about 4 ounces of oil per track day. That oil would otherwise puddle in the intake manifold, foul the intake side of the intake valves and reduce the effective fuel octane burned in the combustion chambers. Just a couple hard pulls on the street or at the drag strip won't generate much oil flowing thru the OEM system.
Old Sep 12, 2020 | 01:54 AM
FringbirdAloha's Avatar
FringbirdAloha
My position has always been: it can’t hurt. Just your warranty.
Old Sep 12, 2020 | 07:49 AM
NY09C6's Avatar
NY09C6
adding something that requires maintenance every few thousand miles (and if you slack on that it freezes up in cold climates it blows out your seals) isn’t an option for GM
Old Sep 12, 2020 | 08:51 AM
ZeroDark30's Avatar
ZeroDark30
And I’m guessing the majority of owners won’t keep the car for 5 years AND 60k, so we’re back to the adage of the supermodel girlfriend and the next guy.
Old Sep 12, 2020 | 08:56 AM
OnPoint's Avatar
OnPoint
The Consigliere
https://www.corvetteforum.com/forums...-corvette.html
Old Sep 12, 2020 | 09:07 AM
gbf_98070's Avatar
gbf_98070
Those drawings are great! Thanks so much for providing that. Is there any way to view the entire set? What document did those come from?
Old Sep 12, 2020 | 09:23 AM
robertbruce's Avatar
robertbruce
Do it!
I have eight on my engine. One for each cylinder.
Old Sep 12, 2020 | 01:37 PM
Avanti's Avatar
Avanti
And, so it begins with another version C.
Old Sep 12, 2020 | 02:45 PM
Glenmcp's Avatar
Glenmcp
Does that get you 224 HP?
Old Sep 12, 2020 | 02:55 PM
Zymurgy's Avatar
Zymurgy
Moderator
Search Google for C8 powertrain media briefing.
Old Sep 12, 2020 | 03:43 PM
AzDave47's Avatar
AzDave47
If you are burning oil rather than gas, yes!
Old Sep 12, 2020 | 04:18 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
ensure they experience painal
Old Sep 12, 2020 | 11:55 PM
kratedisease's Avatar
kratedisease
Can this catch can be modified to work on my wife's mouth ?
Does it come with a spousal adapter hose ?
Old Sep 13, 2020 | 12:56 AM
stormcloak's Avatar
stormcloak
Considering that the scavenged oil = additional maintenance that would need to be dealt with by either the customer or the dealer, no...it probably wouldn't. Cost cutting is a huge part of any mass manufactured car, and a catch can would certainly add expense to a C8 (even more than the correct amount of transmission fluid!)
If someone can provide documentation about the benefits of oil in an intake, I'd be interested in reading it
To Oil catch can
Old Sep 13, 2020 | 01:18 AM
GTUnit's Avatar
GTUnit
C8 has an air/oil separator under the intake manifold.
Old Sep 13, 2020 | 01:40 AM
AzDave47's Avatar
AzDave47
See diagram up above where the Foul air (oil soaked) from that valley oil separator is BURNED IN COMBUSTION. An oil catch can would strip that oil out and keep it from being burned in combustion (knocking down the fuel octane).
I understand that GM would not want a high maintenance device like a catch can, which would have to be drained after every track event, to be included on the regular production car. On the street you could drive 5000 miles and maybe pick up 1-2 ounces of oil. You would get 4 ounces in one track day. This is one area where those that need it should just expect to add it and take care of it's regular draining maintenance.
Old Sep 13, 2020 | 03:09 AM
500's Avatar
500
I can't imagine oil being burned in combustion is helpful in the ever ongoing quest by car manufactures to reduce emissions.
