Not a fan of the shift buttons...and rocker extension question?
Maybe its me. My prior vett's were all sticks, obviously not the case with the C8. I can't stand having to look at the shifter buttons when doing tight maneuvers/k-turns/etc. Love the car (only about 150 miles on it)....but going to need to get used to having to look at the buttons every time vs. the simple feel of a center mounted/column mounted shifter.
On Rocker extensions - does anyone make a aftermarket extensions (like GM accessories) in carbon flash (I dont like the side skirts with wings)
Curious what others think on the shifter & thanks in advance!
Aceman
Aceman
Noreplacement (11-01-2022)
I would have liked a manual. But in the absence of a manual transmission, I like the buttons. The levered design of the shifter buttons reminds me a bit of Lamborghini. It feels more exotic than an automatic shifter stick. Also the stick is useless in my opinion given he paddles are the best way to shift with a DCT (and I make this point as someone who prefers to drive manual). My views is sticks are for manuals, paddles are for DCTs. In a DCT a clean center console with a tastefully designed PRND setup is the way to go.
The following 3 users liked this post by stealthpilot:
E-Ray, 3LZ, ZER, LIFT
Received 9,677 Likes
Aceman
Aceman
To get over my ~60 years with every DD having a 3rd peddle drove in Manual Mode for the first month. After break-in hit the rev limiter twice when leaving a stop sign at the end of my rural road and merging into often heavy traffic on a 4 lane divided highway. Traffic is going and coming from Myrtle Beach to I95 South and certain times have to accelerate fast to merge. BUT 1st gear reaches the 35 mph rev limiter in the blink of an eye and upshift paddle out of position!
Stopped using Manual Mode and for 2 years use mostly Z Mode Power set to Track. Shifts like I was my 2014 C7 Z51 and 2017 Grand Sport. I mostly take back rural roads on the 25 miles to town. Doesn't shift past 5th (C7's seldom used past 5th) and shifts up and down at higher rpm. Don't even have to use the paddle to downshift as just apply the brake aggressively prior to making a turn and it downshifts several gears in the blink of an eye rev matching each. Love the sound. Try it!
I would love to have a real shifter rather than buttons - something like a BMW style than Porsche 911's which I'm not a fan. I'm thinking about getting a rocker extension as well - debating about carbon flash to match everything else on the car or just go carbon fiber and replace the front splitter.
Kcops -
My issue is my spoiler is low profile carbon flash, so there is no carbon fiber on the exterior....i saw one vendor that takes the GM rocker extensions, sands them down, paints them, but was really hoping for something aftermarket vs. something sanded down smooth. I plan on doing the rockers then changing the splitter to carbon flash to keep everything carbon flash.
Aceman
Aceman
I drove manual transmissions for many years. In performance applications they SUCK in comparison to the DCT in the C8 Corvette. If manual transmissions were the bomb they would be used in pure performance applications. They have been replaced.
I would like to experience the 68 Hemi Roadrunner I used to pilot with a DCT. I can surmise it would be fantastic.
If your desire is to maintain the three pedal system the C8 is not for you. That’s OK.
Received 19,558 Likes
'20-'21-'22-'23-'24
If you don't like the buttons for the shifter on a C8, sorry, but your only choice is to go with another car.
stealthpilot (10-31-2022)
It takes what, a couple of seconds to glance down and back? But once you get used to them, you can identify them by touch. Note that some are pull and some are push. You can tell them by feel once you make a little effort to learn their order.
Without three pedals it’s a bit obvious you are not driving a manually shifted transmission. You are driving an automatic transmission that can be controlled manually through solenoid controlled engagement of the gears.
that said I also enjoy a DCT with shift lights in the HUD and paddles. But the whole point of DCT is shift speed and taking your hand off the wheel to shift a lever defeats the purpose.
only an idiot would shift a car designed to change gears in 0.03 seconds by taking their hand off the wheel and using a lever when they could use the paddle with no lateral movement.
Moderator
Received 3,598 Likes
It will take you all of 2 minutes to get used to the "shifter" switches. I don't have to search for them - it's easy. I like the switches every bit as much as the shifter on my AMG. This is Corvette #8 for me. All the previous were manual trans. I would never go back.
4thC4at60 (11-01-2022)
I think the transmission switches are great and very ergonomic. Not so much for the parking brake switch location.
The following 2 users liked this post by Rapid Z:
396tears (11-02-2022),
Red Mist Rulz (11-01-2022)
ACS Composite side rocker extensions in Carbon Flash:
https://acscomposite.com/collections...c8-z51-rockers
Edit: hell, I'll sell you mine for $600 shipped. I've been eyeing the new Z06-style rockers from ACS.
The engineers/marketing/accountants chose not to put a lever on the console along with the paddles. I drove a couple of cars with both and very much liked the options of all three driving styles. .. full auto, manual with paddles, and manual using the console lever. Oddly enough I found that just putting my hand on that console lever made me drive the car more like a manual, than when, in the same mode, I simply used the paddles in manual mode.
I think someone, at the last possible moment, said "Oh, Hell, we forgot the parking brake button!" and they stuck it somewhere there was room, figuring mot people don't use it anyway.
