Reproduction Replica Gloss Black 5-Spoke Rim Wheels OEW-9511109-9511107 For C8 Corvet
Platinum Supporting Vendor
Reproduction Replica Gloss Black 5-Spoke Rim Wheels Package OEW-9511109-9511107 For C8 Corvette
These OE Wheels from PFYC are made with high-quality materials to ensure durability and longevity. These rims have a modern and sleek design with five spokes and a deep concave profile, which gives the car a sporty and aggressive look while enhancing appearance and performance. These CV03 replica wheels are 19x8.5 front and 20x11 rear gloss black 5 spoke rims designed to fit the Chevrolet C8 Corvette. The finishing process includes a black powdercoat foundation followed by two layers of clear coat, not a one stage enamel like competitors. This is the correct way to finish a wheel. They have an absolutely beautiful finish with a superior sheen due to the additional layer of clear coat. Photographs do not depict the superior finish of these black wheels. All OE Wheels rims are TUV, JWL, VIA, SAE or DOT approved, and are guaranteed to be straight and true. Like all quality replica wheels, the CV03 should be washed with soap and water only (no harsh chemicals), and dried with a clean microfiber cloth. Sold as a set of 4 wheels 2 Front and 2 Rear.
These wheels WILL NOT FIT: C8 Z06, Grand Sport, ZR1 models. They Will fit Z51 models. Fitment is not guaranteed for vehicles equipped with upgraded or modified brakes, suspension or drivetrains.
Specifications:
Wheel Size: 19x8.5 / 20x11
Wheel Offset: 52 / 64
Bolt Pattern: 5-120
Hub Size: 66.9
Back Spacing: 6.8 / 8.5
Center Caps: Center caps included, Original center caps will interchange
Application
2020 2021 2022 2023 C8 Corvette Z51
Specifications:
Bolt Pattern: 5-120
Hub Size: 66.9
Application
Received 5,266 Likes
Please, supply weights. Thank you.
Received 7,017 Likes
Is this an asymmetric wheel design where the small, pointed arrow shape on the spokes near the rim should be pointing toward the rear when installed?
Example:
fronts wheels: right and left side
Example:
PFYC (08-02-2023)
