Sponsored by: Wheel Design
Code name Zerv
Old Mar 20, 2019 | 08:50 AM
  #721
Quinten33's Avatar
Quinten33
Originally Posted by skank
Quinten33, you have just saved the day. I remember reading that as soon as ZERV was posting these, GM had the Forum taking these CAD views down only to be put back up by astute members like you. Thanks so much for maintaining these. Do you have them all?
The only other picture I have or know of is from post 33 of the thread “ME Musings and Other Whispers”. If it’s true information, that post is very important.
Old Mar 20, 2019 | 11:12 AM
  #722
skank's Avatar
skank
Excellent Quinten33, just excellent!!!!!
Old Mar 20, 2019 | 12:21 PM
  #723
Walter Raulerson's Avatar
Walter Raulerson
Me too ????????
Old Mar 21, 2019 | 12:36 AM
  #724
ltomn's Avatar
ltomn
is Foosh watching??
Old Mar 21, 2019 | 01:26 AM
  #725
JoesC5's Avatar
JoesC5
From the valve cover design, it appears to be a LT1 OHV derivative and the transmission looks nothing like the ZF DCT that was shown in the earlier CAD drawings.
If it is a Tremec, sure hope that GM has spent the time to get the thing tuned so it's as responsive and smooth as the ZF that Porsche uses. First DCT transaxle by Tremec and first DCT application by GM...…...what could go wrong...….!!!!!!!!!!!!!!!
Old Mar 21, 2019 | 07:49 AM
  #726
Quinten33's Avatar
Quinten33
Well, all of the money that used to go into tuning two different transmissions, testing two different transmissions, beefing-up two different transmissions, and manufacturing two different transmissions will now go towards the development of one transmission(Keep in mind that the 8-Speed is designed and built by GM, not ZF or Tremec). Now throw in a ton of R&D money from Ford for the GT500’s DCT, which is likely a reconfigured version of the C8’s, and you plenty of funding for Tremec to get it right.
Old Mar 21, 2019 | 11:51 AM
  #727
skank's Avatar
skank
These CAD views show both ZF DCT Transaxle (Same DCT thats in the Porsche 918) and the Tremec DCT thats indicated by Zerv's comment above. The ZF unit is a proven unit that has been out for a while now. The Tremec unit hopefully is sorted out and reliable. The Tremec unit is not shown on their website at all. I contacted Tremec for information about this unit and they said they couldn't reveal any specifics on it. Obviously, not until the ZORA is revealed will we find out if the DCT is actually the Tremec unit. There is also a smaller ZF unit that looks very close to the Tremec unit thats shown above for the base LT2 car. ZF also makes a 7sp manual Transmission that is based on the 7sp DCT unit. Both units are shown in the link below.
https://www.zf.com/products/en/cars/products_29326.html
https://www.corvetteforum.com/forums...post1596312478
Old Mar 21, 2019 | 12:21 PM
  #728
Telepierre's Avatar
Telepierre
ZF DCT Transaxle (7DT70HL(A)) shows max torque input rating at 515 ft-lbs. Current LT1, LT4, LT5 are respectively 460, 650, 730.
So probably good to go for "revised LT2" but for the "higher" engines?
Is the ME going to loose one of its quintenessential strengths? Torque?
Old Mar 21, 2019 | 01:11 PM
  #729
BEAR-AvHistory's Avatar
BEAR-AvHistory
Don't think so. We don't know what the C8 power/torque ratings will look like yet. The Tremec 7DCT is listed for FORD's GT500 with is already announced at 700+BHP. Your torque limits don't really apply as a DCT specific limitation since the Porsche PDK 7DCT is already supporting more then 515ft-lbs in the 700 BHP GT2RS.
Only limitation is the quality of the parts they put into the clutch assemblies. The gear box section & gear set is similar to any normal manual clutch operated MT gear set which are already covering the Corvette's torque.
Old Mar 21, 2019 | 04:15 PM
  #730
Telepierre's Avatar
Telepierre
Thanks!
I'll admit that your reference to the FORD GT500 has me more reassured than the GT2RS which currently peaks at 550 ft-lbs.
I read the 500's torque will come at 650 ft-lbs (https://www.roadandtrack.com/new-car...aked-document/) which is the current C7Z06 rating. I know that although good for hi-rev motors, DCTs have been technically limited to the 500ish ft-lbs mark for a while but if they are coupling it with the 650 GT500 I suspect it will be reinforced.
Weight/dimensions comparable to current C7 I would want the base ME to be fairly close to the 500 mark... torque is what moves the car after all...
Cheers
Old Jun 26, 2019 | 04:51 PM
  #731
skank's Avatar
skank
This thread started it all. The all time most valuable thread in the entire C8 Section.
Old Jun 26, 2019 | 08:29 PM
  #732
snow's Avatar
snow
St. Jude Donor '10, '17-'18-'19
Werd...
Old Jun 26, 2019 | 08:49 PM
  #733
Quinten33's Avatar
Quinten33
ZERV gave us so many questions but a few very concrete answers. I think that a lot of forum members forgot about the CAD images he leaked and the details which they show. But they aren’t important anymore, mostly because the C8 reveal is just around the corner. I hope that I remember this thread whenever the forum gets around to waiting on the C9.
For those of you wanting the pictures ZERV had posted on the forum, scroll up and you’ll see them all in one post.
Old Jun 26, 2019 | 11:56 PM
  #734
skank's Avatar
skank
Post #718 by Quinten33 is amazing. There was so much info exposed from those photos. Great job Quinten33
Old Jun 27, 2019 | 08:04 AM
  #735
Rkreigh's Avatar
Rkreigh
Originally Posted by sunsalem
One more reason not to go AWD with a Hybrid Sportscar....
I agree. While the "exotic" design of a TT v8 in back and electric motor up front the weight penalties make the car have to overcome dragging it's lard
@$$ around. The NSX racecar dumped the battery and motor and upped the power on the TT v6 and it's a different car.
sell these at around 80k (hmmm,,,, sounds like a c8 price range??) and NSX would be a mover. Right now, they aren't doing so well in sales which is putting it kindly
One of the most advanced cars in the price range is an epic fail. Hopefully GM learned something from it!!
Keep the heavy batteries OUT of the vette. Car is too piggy as it is with all the creature comfort and mandatory safety stuff.
my "build" is a TT vette at much less than 3300 lbs that hauls the mail with around 800 hp. That will be enough if it can be hooked up.
the brits seem to be doing fine with the mclaren's and traction. GM needs to invest a bit more in boost by speed technology for traction control solutions which is much easier to do with turbos.
