Sponsored by: Wheel Design
Code name Zerv
Old Dec 17, 2017 | 12:54 AM
  #81
wv8090's Avatar
wv8090
Originally Posted by senah
where's the turbo? this appears to me to be naturally aspirated. the turbos reportedly will be combined with the 4.2 and 5.5 dohcs.
That is clearly a pic of a cylinder head/exhaust manifold/turbo and intake tube......
Old Dec 17, 2017 | 06:02 PM
  #82
bub's Avatar
bub
Looks to me like it will have adjustable suspension like the Ford GT...gaging by the pneumatic or hydraulic line apparently emanating from the bottom of the LF shock/spring assy.
I assume this because the brake line and ABS speed sensor wire are also visible in the same view...this and zooming in on the bracket that these mount to on the frame indicates 2 significant hoses' hard mounting points on the frame where they will transition to tubing.
Old Dec 17, 2017 | 06:20 PM
  #83
Quinten33's Avatar
Quinten33
That’d Be cool. The only thing I like about the GT is how it drops to the ground in track mode. And they use the same pump for the suspension and wing, which is smart.
Old Dec 17, 2017 | 09:27 PM
  #84
elegant's Avatar
elegant
bub, that is very exciting analysis. Thank you very much. I heard a while back that GM had at least contracted with a supplier to develop such a system for the ME, but wondered whether it was going to make it into production.
A “front axle lift system” (which is what Porsche calls it, and is priced by them at $2,590) would be an extremely exciting option for many Corvettes owners, especially those of us who have lowered our C7’s and who typically encounter steep driveway aprons, speed bumps, etc.
Months ago, at a gathering of about six C7 owners, we unanimously agreed that at roughly $2,500-$3,000, we would all buy it when/if it became available for our next Corvette.
I would be happy to avoid the “45 degree, incline-approach method” necessary almost daily. Count me in. Porsche’s works to 37 MPH; maybe GM will even have a automatic triggering method based on the 2016+’s three front fascia cameras.
Thanks again bub. Still smiling after reading your post.
Old Dec 17, 2017 | 09:30 PM
  #85
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
This coming year is going to get really interesting. I have a feeling there will be more of these seeing daylight.
Old Dec 18, 2017 | 03:41 AM
  #86
ZERV's Avatar
ZERV
Navigator
Old Dec 18, 2017 | 03:58 AM
  #87
SSsedanM6's Avatar
SSsedanM6
This new member only has 3 posts, so these CAD leaks must be bogus, right?
What do you guys notice in the new leak?
Old Dec 18, 2017 | 04:10 AM
  #88
senah's Avatar
senah
doesn't show on the pictures i'm seeing. i see one picture that has 4 exhaust tubes coming from the side of the engine going to a fairly complicated muffler, but no turbo system associated with it. maybe you have a picture that isn't showing for me. with a turbo system, the 6.2 can have an easy 700+ hp.
Old Dec 18, 2017 | 06:35 AM
  #89
Quinten33's Avatar
Quinten33
Originally Posted by ZERV
Single throttle body, dual air intakes? Is one side for a turbo? And those aren’t mufflers to either side, but catalytic converters. But the cylinder heads look a little small imo, meaning that this may be a pushrod engine.
Old Dec 18, 2017 | 07:23 AM
  #90
bigblock427's Avatar
bigblock427
Old Dec 18, 2017 | 07:58 AM
  #91
skank's Avatar
skank
Looks like they will have a window to see the top of that designed plenum top. Most mid engined exotics are showing off their engines.
Old Dec 18, 2017 | 08:03 AM
  #92
NoOne's Avatar
NoOne
Dual injection system Port and Direct it looks like.
What I cannot figure is the air element looking thing under the TB intake tube.
Old Dec 18, 2017 | 09:20 AM
  #93
Quinten33's Avatar
Quinten33
Lamborghini uses dual injection on their V10 and V12 engines. They also have a similar dual intake system, but with dual throttle bodies. This is interesting because that engine has to be sucking in a lot of air to need that much fuel. It has some form of forced induction.
Old Dec 18, 2017 | 09:34 AM
  #94
Dominic Sorresso's Avatar
Dominic Sorresso
Seems to me the engine strategy is similar to what happened with the introduction of the C4. GM brought out the 84 with the previous generation CrossFire motor followed by the newer technology TPI in 85. So we see the C8 potentially introduced w the C7 6.2L pushrod. Will the rumored DOHC motors be introduced and available only AFTER the initial C8 debut? Or simultaneously?
Old Dec 18, 2017 | 10:00 AM
  #95
f-16pilotTX's Avatar
f-16pilotTX
With a intake manifold design like that, I am sure they will have it visible by the use of glass or some other material. Wow, excited stuff! Can’t wait for more! Hmmm I wonder if the base C8 will actually be a OHC, V8 with one (or maybe 2) turbos? Interesting.....
Old Dec 18, 2017 | 12:59 PM
  #96
nvusgt's Avatar
nvusgt
I know how people around here feel about Stance and other companies in the same ballpark, but they have standalone kits (air or hydraulic "cups") that can be installed on a front coilovers setup. Most expensive being the KW HLS (hydraulic lift system) which can range from $3-8k+. Obviously OEM would be ideal but if people are lowering their car, having spent money on a nice coil setup, might be worth looking into one of these "cup" kits, which by the way does not alter the handling, or geometry etc. Head to YouTube for some vids, they're actually really clever systems.
Old Dec 18, 2017 | 03:29 PM
  #97
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Did anyone manage to see this image???
To Code name Zerv
Old Dec 18, 2017 | 03:53 PM
  #98
firstvettesoon's Avatar
firstvettesoon
What image? Did you save it?
Old Dec 18, 2017 | 04:08 PM
  #99
LightningBolt's Avatar
LightningBolt
Its up on Jalopnik
Old Dec 18, 2017 | 04:17 PM
  #100
vetteman41960's Avatar
vetteman41960
I still see it on post 129. but I seen it around 4:00 am when it was posted.
I am hoping we get a good shot of the body now. It's clear the OP has more than just the 3 or 4 he posted. I hope so anyway. While these shoots are cool I think we are all waiting to get a glimpse of the side profile or of the front or rear body clip.
Hopefully the OP is saving the really good stuff as an Xmas girt to all us Corvette guys that can't wait another 10 or 12 months to see the C8.
