Servicing mid engine
In many cases Mid engine cars need the entire engine removed for servicing. Some are easy, others are really difficult. All take more time and labor to do as well as replace parts that need to be replaced while you are there. Do a clutch in a Ferrari 308 and you might as well replace the timing belts, bearings, oil seals, and water pump at the same time.
Many times, in an effort to make the engine and gearbox in a tighter package than what is available space up front, they use exotic engineering that is more costly to make and assemble, as well as repair if needed. Engines are often transverse mounted to make the length of the engine and gearbox shorter.
As to training, I also offer the Ferrari 328. There are two drain plugs on the bottom. One is engine oil and one is gearbox oil. They look pretty much identical. One is easy to find, the other takes a bit of searching. I can't tell you how many backyard mechanics have drained the gearbox oil and then overfilled the engine oil by removing the wrong plug.
Working on Mid engine cars is just more complicated and difficult, which is why the preferred method today is drop the entire subframe and work on everything separated from the car. That's rare on front engine cars.
Ya don't even have to go to the hardware store neither... why I just went right down the street to Walmart... there were hole-saws all over the place.
One of the spark plugs on the Tahoe is kind of a pain to get to. I can actually change the plugs on my mid-engine Gallardo easier, 62k miles on it and nothing but the same thing replaced on the engine as the Tahoe.
Also I took the transmission out of my Tahoe last year to rebuild it without a lift.
You have to get a C5 almost four feet off the ground to snake the exhaust out from the rear bend.
Depending on the design of the exhaust manifolds, spark plugs might be pretty accessible from underneath the car.
On the flip side, understand, that while the technicians may argue the point at times, manufacturers have a vested interest in minimalizing the overall cost of warranty work. If, for example, removing the engine is going to almost always be required, then, they will most likely make dropping the cradle as simple as possible.
As far as parts, the good news is that this is a mass produced car, and contracts and par levels for parts have already been decided. So it won't be like they are one off, hand built individual pieces of art. If the transmission goes out, it won't be like you'll have to wait 6 months for GM to hand build you a new one.
But things like oil changes, which will be about all most people will face at least for the first few years, will be addressed in design. I would almost bet that the C8 will be exclusively dry sump system.
