Sponsored by: Wheel Design
Water spots!
Old Mar 14, 2020 | 08:57 PM
  #81
Rob4092xx's Avatar
Rob4092xx
Won't a ceramic coating like Gtechniq C4, made for textured black plastic trim, work?
Old Mar 14, 2020 | 09:06 PM
  #82
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
I'm going to apply a ceramic coating after I get it cleaned up, but the spots have to be removed before applying the coating.
Old Mar 14, 2020 | 10:05 PM
  #83
SD1's Avatar
SD1
You need an acid to break down the alkaline deposits (scaling), use something MILD, even DI water can break down mild scaling, let it sit (dwell) on the spots for a few minutes, just use caution as a strong acid can mar/degrade plastics, once you have it clean, put some rainX or other hydrophobic agent to prevent future deposits.....
I don't know if this stuff will repel water, but it is fantastic on plastics.... last LONG time...
https://www.homedepot.com/p/Rejuvena...IPES/206161494
And, rain water is usually NOT the issue, generally speaking does not have significant mineral content....
Makes me wonder about how water is routed through the car in rain/car washing? Think that question has been asked, but still wondering.
Old Mar 14, 2020 | 10:06 PM
  #84
Rob4092xx's Avatar
Rob4092xx
Which are you going to use? I have had tremendous luck with Gtechniq C4.
Old Mar 14, 2020 | 10:10 PM
  #85
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
Anyone try Mckees's yet?
https://www.autogeek.net/rv-water-spot-remover-gel.html
Old Mar 14, 2020 | 10:15 PM
  #86
E.T.D. Corvettes
2015 C7 of the Year
I've been using Adam's ceramic coatings lately.
Old Mar 14, 2020 | 10:20 PM
  #87
24/Eray's Avatar
24/Eray
Anyone brave enough should try acetone on an inconspicuous area of all else fails.
Old Mar 14, 2020 | 11:07 PM
  #88
Michael A's Avatar
Michael A
I would use a chemical that dissolves the water solids such as vinegar. You might even try dishwasher Finish Jet Dry. Jet Dry even removed caked on water solids in my dishwasher. Looks like new in there now.
Old Mar 15, 2020 | 06:24 AM
  #89
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
One thing I viewed on the Net, that was logical to try with any potential solvant, is exposure time. The removable plastic tray at the bottom of a refigerator cold water dispenser required soaking time in vinegar to compleetly remove hard water spots.
Perhaps soaking a rag with the potential solvent and leaving it in contact with the surface may help.
Old Mar 15, 2020 | 09:59 AM
  #90
bzagorski's Avatar
bzagorski
Water spots are a bitch. I have Ferrari 360 and water spots in the engine bay are a mess to get off. Vinegar does not work. Maybe because it bakes in with the heat of the engine. A light polishing compound is the only thing that I have found that works. Also if you get caught in the rain dry the engine bay as soon as you can.
Old Mar 15, 2020 | 10:41 AM
  #91
HooosierDaddy's Avatar
HooosierDaddy
Thanks for the real world experience input. It would be my guess the combination of the collected dirt, then getting wet and the engine cooking it is making for some tough water spots. Now that the Corvette has this issue to deal with, there'll be more demand for a product that can remedy these spots. Someone will come up with a simple solution and make millions solving first world problems.
Old Mar 15, 2020 | 11:02 AM
  #92
baf2000_1's Avatar
baf2000_1
I have used muratic acid from Home depot in engine bays. Dilute 10 parts water to 1 part muratic in spray bottle. Gets off scaling on plastic and metal . But do small test section first.
Old Mar 15, 2020 | 11:24 AM
  #93
JerryU's Avatar
JerryU
Sounds similar to this dude who shows removing heavy water spots with examples of various products on car finsih. He calls the "stuff" that worked best "acid wheel cleaner" diluted 2:1 with water.
Good video
Old Mar 15, 2020 | 12:12 PM
  #94
rrichar2591's Avatar
rrichar2591
I think he used a dilution ratio of 2 parts water to 1 part acid wheel cleaner. Good video and thanks for posting. I have a C5 that had hard water spots all over the radiator cover and could not find a way to get them out to my satisfaction. They were very noticeable at car show events so I just bit the bullet and installed a new cover and am much more careful now. If somebody finds a way of removing these things I'll be interested.
Old Mar 15, 2020 | 12:17 PM
  #95
SD1's Avatar
SD1
BAD idea....
Old Mar 15, 2020 | 02:24 PM
  #96
JerryU's Avatar
JerryU
Originally Posted by rrichar2591
I think he used a dilution ratio of 2 parts water to 1 part acid wheel cleaner. Good video and thanks for posting. I have a C5 that had hard water spots all over the radiator cover and could not find a way to get them out to my satisfaction. ….
Thanks, fixed the post so folks can follow correctly I just made 2000 so hopefully someone getting their C8 before me can post a good safe solution!
Old Mar 17, 2020 | 10:50 PM
  #97
kong's Avatar
kong
Originally Posted by ArmchairArchitect
No, because it's a dealer detail department, not a professional independent one. Big difference. Most dealer detail departments don't even know how to wash a car properly without leaving swirl marks.
That's why new car buyers should tell dealers to leave the plastic wrap on the car, then unwrap it yourself when you arrive at the dealership. And then do your own wash/detail or take it somewhere else.
Problem there is that you cannot properly inspect the paint before buying the car. Dirt can hide all kinds of stuff. I want to see the paint then if there are some swirls my detailer can easily get them out.
To Water spots!
Old Mar 19, 2020 | 11:27 AM
  #98
Hurdler's Avatar
Hurdler
They must have some awful hard water in BG if the water test did this. I picked my car up yesterday - same thing but not a big deal. I have-not tried to get rid of them yet but the dealer mentioned there were some on the paint that they worked to get out as well.
Old Mar 19, 2020 | 03:26 PM
  #99
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Yes you can. As I said (prior to completing the purchase):
"That's why new car buyers should tell dealers to leave the plastic wrap on the car, then unwrap it yourself when you arrive at the dealership. And then do your own wash/detail or take it somewhere else."
Old Mar 19, 2020 | 03:30 PM
  #100
C8broughtmeback's Avatar
C8broughtmeback
I guess I need to add hose, bucket, soap, microfiber, quick detailer spray, clay, and polish to my luggage for the trip to NH. There goes all my frunk space!
